4mm?
PS My Vanilla 126 balances much nicer with the rear of my 5-spot. The set up has 2 2mm spacers in the LL control rod, 3 plus fox-20mm spacer in the RL upper, and 13 2mm in the RL.
Are you really talking about 4mm here? Come On Now!
You must be very sensative to your travel ....126 vs. 130. Maybe the Pike is the fork for you. Then you can really dile it in...+ or 1mm.
Good Luck
Good Luck
