I got my Ibis Ripley LS built with Shimano 12 by my LBS. I have XT shifter and SLX casette (10-51T) and rear deraillure. It has a 32T front ring on XT cranks. It just doesn't shift right. On the stand the 51 clicks and in the mid gears shifting to a smaller ring doesn't shift or is really slow. I adjusted the cable tension, end adjustment screw all over from aligned to the marker to way off. I adjusted the low adjustment bolt all over. Things only get marginally better. My current guess is the chain is too short. I asked the mechanic and he said that he used all the links that came with the SLX chain. I saw a picture at:
https://dansbikeblog.com/article/how-calculate-correct-chain-length-shimano-12-speed-drivetrain
My top and bottom positions don't look like this picture. It looks like I have less links.
Can someone tell me how many links you have for the above teeth counts?
Help.
TIA
Help.
TIA
