Is anyone using the new SLX 12-36T cassette with a normal SRAM X series derailluer? For reference, I run 1x9 and I'm using a short cage X0 with a single 30T front sprocket. I'm currently using 11-34 just fine but would like to go up a bit if possible for a little more climbing ability since it's a 29er:thumbsup: I understand all the data says it SHOULD work but I'm curious if anyone has actually DONE it??? The 34T big gear in the rear looks like it's just about as big as the X0 will handle smoothly and I don't want to drop the cash for the 36T if it won't shift smoothly:idea:
Doesn't SRAM print the capacities for their derailleurs? For a 12-36 cassette and one ring you just need a mech with 24t capacity right? Correct me if I'm wrong.
You might need a longer B tension screw to get enough clearance to the 36T cog.
You may also find that your freehub explodes with the extra torque that the 36T cog applies. Shimano recommends the steel freehub body from the Deore hub for that cassette.
Uh oh! Explosions are bad!!! I'm not in need of it bad right now, it's more of a "when my current cassette wears out" upgrade. My 34T is just fine but when I have to replace, might as well upgrade
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Mountain Bike Reviews Forum
