1 - 20 of 21 Posts
· Out spokin'
In cog? Neato!
Was bored this rainy morning so wandered around Amazon and came across this bleed screw for 11 speed brakes.
Automotive tire Product Tread Camera accessory Tire
Didn't know there were 11 speed brakes... guess this one only goes to eleven?
If you use this on a 12 speed bike, will your 11 speed brakes fail to stop you?
=sParty
· Out spokin'
In cog? Neato!
Discussion Starter · #13 ·
They work perfectly until you get to the big cog. Then they don't work at all.
Ha! And to think until now I'd assumed they'd work on the big cog but not the little one. Whew! From now on I'll know which one to avoid. :)
=sParty
· Registered
=sParty
Lord, the high gear is the high speed gear! definitely need brakes for that. The big cog is the climb gear, you're only using that when you're doing 3-6 mph up a steep hill. Who needs brakes for that?
What kind of fool designers did you think made these 11 speed brakes?
· Out spokin'
In cog? Neato!
Discussion Starter · #16 ·
This is America -- I expect they'd design them to eliminate functioning in the gear you'd most them in.
How better to motivate you to buy new 12-speed brakes?
=sParty
1 - 20 of 21 Posts
