1 - 2 of 2 Posts
So a few things. The first thing you want to know is if the axs red etap shifter will pair with the axs xx1 derailleur. I bet it would, but you need to know for sure. This article seems to indicate it can be done. https://www.velonews.com/2019/02/bi...eimagines-gear-range-with-red-etap-axs_483097
I've done no research beyond that but here's some additional thoughts.
You'll want etap cranks assuming your frame can accommodate the narrow spindle. (if you're planning to use a hardtail mtb frame, this will almost certainly be an issue.) Flat top chain. Xx1 derailleur and any sram 10-50 cassette. Oh. Looks like etap force shifter might be available now, might save you some over red.
Sent from my Pixel 3 XL using Tapatalk
1 - 2 of 2 Posts
