1 - 20 of 2315 Posts
11-40T/42T conversion: OneUp vs. Wolf Tooth vs. Hope
Now we have two similar products to create a cheap 1x conversion with 11-42T cassette for sram and shimano. Full shimano 11-42 drivetrain, dream comes true!
OneUp Components 40T/42T Sprocket
Wolf Tooth Components 42T Giant Cog
There is also the general lee cassette, which replaces 4 cogs and cost twice, let's leave it out now due to cost.
What it looks to me so far comparing the two, the wolf tooth has many advantages:
  1. No spacer, dedicated models for SRAM and Shimano. Should create wider cog-freehub interface. Less freehub wear, better.
  2. Comes with extra long B tension screw in case your derailleur does not have enough clearance from the 42T cog on the original screw.
  3. Known reputation and highly regarded.
  4. Looks like more teeth shaping, should aid shifting.
  5. Price for 42T + 16T: Wolf Tooth is $90+$15=$105, Oneup is $90.
That's what I can tell from the web pages. Looks like Wolf Tooth is a better choice at higher price.
From reports Shimano derailleurs have more problems dealing with 42T cogs than sram. 40T may be a better option for shimano users.
OneUp Rad Cage seems to be the ticket for shimano users and greatly improves shifting performance.
Did you install it and how is it working?
Post your setup for others to know
  • Frame model and year
  • Derailleur model and cage size
  • Cassette & chain
  • How it works
Updates:
SunRace CSMX3 10sp cassette, 11-40 and 11-42
  • $60
  • Complete cassette with good teeth ratios
  • Steel cogs on aluminum spider, big cog is aluminum
  • Less hacky than piecemeal cassette extensions
  • 383g for 11-40
  • All steel cogs versions coming soon, will weight 414g and 448g
  • User reports it shifts fine
Hope 40 T-Rex Adapter
  • $90
  • Sram and Shimano specific cogs with no spacers
  • 4 shifting gates (OneUp and WT have 6 gates)
  • Hope reputation and diehard fan club
  • No 16T cog
E13 Extended Range 40/42T Cog
  • $70 (on Jenson), $60 on outsideoutfitters
  • Sram only 42T, Shimano 40/42T
  • 6 shifting gates
  • E13 reputation
  • No 16T cog
twenty6 40/42T Cog
  • $95
  • 5 shifting gates for 40T. 42T I assume its 6.
  • 10 colors
  • No 16T cog
Absolute Black 40T Cassette Cog
  • $74
  • Shimano 40T only
  • No 16T cog
wolftooth is domestically manufactured, and they're great people.
oneup appears to be a canadian co (with offshore manufacturing), but the who's and where's are all shrouded in secrecy for some reason; bit of a faceless company.
both seem to be solid products, but i gave my $ to wolftooth based on above.
Went with Wolftooth. US company with US manufacturing and still a better price. I guess unless you need the versatility (Shimano/SRAM) or green ano...there isn't much reason to go with 1up unless they undercut WT. Even then if the price is close for equal or better product I'm buying US over overseas.
No review since I don't have it yet.
  2. $90 vs $100, $10 cheaper.
  3. Comes with extra long B tension screw in case your derailleur does not have enough clearance from the 42T cog on the original screw.
  4. Known reputation and highly regarded.
  5. Looks like more teeth shaping, should aid shifting.
These are my exact thoughts. I'm waiting for the Sram versions to become available and more reviews to pop up before making any decisions, though.
OneUp is from so cal...at least thats where my cog shipped from.
The cassette specific cog seems like marketing to me. WT's way to one up OneUp. There has been many reviews on the OU 42t and nobody has mentioned poor shifting.
I can see WT making different cogs because of the different spacing with Shimano and SRAM cassettes so you don't have to use shims like with the OU. Unless there is some kind of comparison where is shows a discernable difference between the Shimano and SRAM specific cogs...its all marketing.
Dont Rep me
Marketing or not, more competition means better and cheaper products for us consumers.
aka bOb
You made a good purchase, you don't need to help justify it by putting down another product or company. I have been guilty of this a time or two.
OneUp Components 42T Sprocket
That's what I can tell from the web pages. Looks like Wolf Tooth is a better choice.
Anyone tried both? Or maybe the hot and new WTC Giant Cog? (OneUp has many reviews already)
I can not compare Oneup to WT, as I have a German made 42T. I will say this though, the Wolf Tooth front chainrings are great products. I like them better than the Sram xx1. They run so smooth and quiet. Because of this, when I replace my 42t I will get a Wolf Tooth. They also have really good CS.
People get way to sensitive about things.
This is a "vs" thread and I'm just giving my opinion.
If WT can show that there is an improvement in shifting by having a manufacturer specific cog...I'll buy one. I do have more than one mountain bike.
Since these 42t cogs are the hot item for the moment...manufacturers are thinking marketing and one upping. How can I market my product that does the same thing, is manufactured with the same equipment out of similar materials to be different?
Discussion Starter · #16 ·
Why not do a 44-11 10 speed or something like that so you still keep the range and don't need a special freehub or der. Wouldn't it be just like a xx1 but missing one gear in the middle somewhere?
I think they would need a special derailleur for that huge gap. Shimano puts a well designed complete package, I find it hard to imagine they would just throw a cassette out there without a fully working kit. for example, even current derailleurs need an extra long B tension screw and thats with 42, imagine with 44. They would probably reengineer the geometry of the derailleur to be closer to the small cog, or use tricky cage like sram. And there is a the question of whether freehubs can handle the torque. Like OneUp says in their blog, too small front ring and heavy riders put enough torque for premature failure of hubs. There is definitely more work to do than just a cassette, but I also think its just a matter of time until shimano puts out a 1x. If I have to guess it will be 1x10 and work with existing cassettes. I can be totally wrong on this guess, don't place bets.
As CozXountry has said there is the issue of the derailleur, but also there is little difference between a 42 and a 44 when you start from a 11x36 cassette. Look at the ratios for a 32 chainring
Cog: 26, 28, 30, 32, 36, 40, 42, 44
Ratio: 1.230 1.140 1.070 1.000 0.889 0.800 0.762 0.727
fhe jump 36 to 42 gets you an almost perfect interval ratio decrement (compare 32 to 36), 44 gains around a 1/3 of an extra gear, 40, like AbsoluteBlack is doing, is also not that great giving a ratio that is less decremental than the gap 32 cog to 36.
A 10 cog also gains relatively little, look at the ratios 10, 11, 13
3.200 2.910 2.460
the decrement between 11 and 13 is good, 11 to 10 is kind of silly because it only gets you a 1/2 of an extra gear (at a cost of more than $1000).
11x42 is huge for most uses, but for a racer or even more spread the way to go is 9x42, like Leonardi Factory is going to offer http://forums.mtbr.com/drivetrain-s...rdi-racing-9x42-cassette-10-speed-895767.html, 9 really gives you an overdrive gear ratio: 3.560
I installed the 41 Ebay cassette. The der. is completely stressed and I would find it hard to believe that the der would have any longevity.
The B tension screw bends really easy because they hit the stop at an angle . Wasn't comfortable with the setup, back to 2x
One of the companies provides a longer B screw. It would be smart to use a tougher material than mild steel
There's always next year.
+1 on this. Wondering when Shimano or Sram will make a 42T or 40T 10sp. cassette, if ever?
+2 (or a 1000) I would think though the only hope would be from Shimano, not SRAM. SRAM's all in with their 1x11 model, and from a company ($) perspective, there is little to no reason to make 42T cassette, as it gives your customers less incentive to upgrade everything and get to 1x11.
I've said it elsewhere... I'd buy more than a few Shimano 10 speed cassettes with a 42t option. Heck, done right, it'd be a great marketing device to appeal to tied-in-the-wool SRAM folks who can't afford the jump to XX1 or XO1.
Evil Calling, Lyrik, CrankBros Synth, Maxxis EXO+DHF/R, CodeRSC, X01/GX AXS, Renthal, 9point8, Ergon
I've ordered the Wolftooth, their stellar narrow/wide rings plus the fact the GC is Shimano specific (no spacer required) and comes with the B tension screw shows they know what they are doing.
