Shimano says to go big, big plus two links. FWIW.Cyco-Dude said:personally, i wouldn't worry about it. it's not like you'll ever end up in the big-big combo anyway. if you want to play it safe though, you can size the chain normally (loop it over the big ring and largest rear cog without running it through the rear derailer, and add one full link).
Chains are cheap and a fresh one on your ride is always a great way to start a new season.cjbiiv said:Thanks everyone. I checked out the size of the 11-32 chain and, well, it was a lot shorter than I had expected. Not that I ever use the big chain ring much but I just felt better putting on a new chain that was sized right. Now, if I could only find the short piece of chain I kept when I sized the chain with the old 11-32, I'd be all set with a real spare... Thanks, again.
