1 - 20 of 21 Posts
Banned
ok - the fork is finished and weighs just 1076g at 168mm steerer lenght!
as decribed in the other thread "my 1100g SID-Project" https://forums.mtbr.com/showthread.php?t=10111 i combined a 02 SID Carbon steerer-/crown- assembly with 01 SID Race internals.on the lowers i shaved the disc-adapter and reinforcement completely away and sanded the colour completely away before applying just a hair of black paint to prevent the magnesium from corrosion.
here's the whole thread again:
here's how it all started:
on the far back is a 02 SID Blackbox from Thomas Frischknecht, in the middle the disassembled 02 SID Carbon and in the front my 01 SID Race (1140g with shaved disc-adapter and 168mm steerer).
here's the 02 SID Race Carbon internals:
here's the 01 SID Race internals (no lockout!):
here's the 01 SID Race crown-/steerer-assembly that got replaced with the carbon one(168mm lenght):
here's the Carbon steerer-/Crown assembly cut to the same 168mm lenght:
here's the shaved and sanded lowers.note the missing disc-adapters.bushings still installed but no seals:
and here it is again with new black paint:
and just for comparison the standard lowers of the SID Blackbox:
and here's the assembled fork,grease and oil all inklusive - 1076g !!
i will apply some stickers later adding 1-2 g ;)
another view:
Lactic Acid is my friend.
wow!
That is really nice, nino. I'm impressed. Please give us a full report on how it performs, and pics of your complete bike.
That's quite a big difference in weight between the 02 and 01 internals. I wonder what the claimed enhancements from 01 to 02 were from RS. Is the entire difference accounted for by the lockout?
Banned
Discussion Starter · #5 · (Edited)
almost right...
it's the internals of a 01 SID Race combined with the Carbon assembly of a 02 SID Carbon.the lowers of those forks are the same but i reworked them as described above.the deep blue colour simply added too much weight.
the 01 SID Race had internals without a lockout and without any rebound adjuster.the 02 SID SL / Race / World Cup all share those same internals i posted above which weigh 358g and have adjustable rebound and manual lockout.
i already rode the 01 SID Race for 2 years and found a setting which suits me fine. I don't need a lockout or rebound.for me a fork has to take the sharpest hits...all the rest is done with body english.stiffness for sure isn't on par with lets say a FOX but i never had any complaints.i weigh 150 lbs so that's really not a big concern. my fork has 63mm of travel which suits my HT. i once tried a 85mm SID SL and steering got too slow for my taste although the fork would absorb the bumps a bit better.anyway - i still prefer the 02 SIDs over anything else.
maybe a few more grams
nino, you might be able to save a few more grams with enduro fork seals
http://www.enduroforkseals.com
I installed them on both of my forks (2002 Duke Race and 2004 Duke SL U-turn) last weekend, and it seemed to lower the weight a bit. I say seemed becuase I didn't think to weigh just the seals until after they were installed, so I only have before and after weights for the complete fork. I also changed the oil at the same time, so that may have affected the weights.
Duke Race original seals - 1563g
Duke Race enduro seals - 1549g
Duke SL original seals - 1932g
Duke SL enduro seals - 1916g
Anyway, the enduro seals definitely don't add any weight, and they are much higher quality than the original seals.
Thanks Nino...
for your explenation! Do you think it would be possible to change my 02'internals with lock-out with the internals of a SID'99 without lock-out? Seems like getting rid of the suspension-lockout would save me about 150 grams.
I'm just asking you because it seems like you have alot of exprience with suspension forks!
Banned
Discussion Starter · #10 ·
seal weights...
if i remember right the standard seals weigh 23g/pair.
might be that there are other seals that are a bit lighter, who knows? BUT from 01 SIDs got those xxx-seals which are far superior than the previous ones.that's why "enduro"-seals and others started to sell their own seals.later the SIDs seals were fine.
Banned
So in other words it rides like crap?
Banned
Discussion Starter · #12 ·
well enough for me...
no 4 bar linkage, discbrakes and sophisticated suspension is needed for me.just a lightweight HT and a capable rider.
Banned
Discussion Starter · #14 ·
mexico...
south of Cancun in Playa del Carmen. awesome beach and water,no biking.i rent a steel beach cruiser once for just an hour to go "shopping" in the village and it beat me! that was the slowest bike i ever threw a leg over.i really had to work hard just to get that thing going on the flats (singlespeed)....
i was here.a location like in paradise and really as pictured. not crowded at all even when it was fully booked:
http://www.shangrilacaribe.com/photos.html
Great build! :)
Nino, that fork is just amazing! Have you thought what kind of decals you will attach into it ? The black SID logos with white letter outlines would be cool...
BTW: You don't happen to have any '01 SID Race's laying around that you would like to sell, do you ? I would be very interested! I have a 2000 SID Race (1195g) now but the needle valves are pain in the a$$.
How about the Vuelta mag brakesets - still have them for sale ?
Banned
Discussion Starter · #16 ·
i have, i have not....
i have a almost new 01 SID Race BUT there are no more Vueltas! i try to get some more but it seems they are all gone.
contact me off the board:
[email protected]
almost right...
Can the 2001 Sid race damper be serviced somehow? I got the oil out of the cartridge, but cannot seem to replace it. Thx for any advice!!!
monster member
Lol! I almost wrote back something like "Hey Nino, glad to hear from you! Haven't seen you around since I was reading Weight Weenies a lot 10 years ago!".
Nino was a good and enthusiastic contributor back then. I hope he's doing well.
1 - 20 of 21 Posts
