i just installed my tuned scandium BB in my roadbike last weekend and it performs great. feels really stiff.
- i started with a 120g scandium BB (68/108mm BSA)
- removing the middle spacer tube brought it down to just 104g . but this leaves you with no option to thighten it. the cups might become loose...maybe Loctite would do the job of hindering it from becoming loose but i preferred a more serious way: i switched out the left side cup with a cup i had that is a little bit longer outwards and allows the use of a counternut. this way i can adjust bearing play and fix it thight. weight is 2g more though: 106g ;(
all together, including the really long bolts you have to use the whole weighs now 134g. that's the weight of a FRM Al BB WITHOUT spacer tube and crank fixing bolts! the FRM Al-crankbolts weigh 21g, the spacer tube another 17g...
best of all: the cups are still long on both sides ( inwards) and i will reduce their lenght. this might save a couple of grams . i guess it will be just about 100g when done
