You need to run a shock that's 6.5 x 1.5. That will give you the same 100mm of travel. The frame limits you to this size because of the pierced seat tube. It's wayyyy better then the Triad. Worlds better. The Triad has that issue - you either get small bump compliance or bottom out resistance, but not both.
I picked up my RP23 for $190. I swapped out the shock reducers from the Triad and mounted it right up no problem.
