1 - 2 of 2 Posts
· Registered
Hello,
My current bike has an 80mm coil fork.
I'm looking to upgrade it to a bigger or better fork,
I was wondering if there is any safety concerns on running a 100mm fork on it?
I have heard that there could be concerns of the head breaking or the frame since it was not made for a 100mm fork. is this true?
Here is the fork I was looking at:
http://www.pricepoint.com/detail.htm?stylePkey=18548&style_id=315%20ROCT39
I chose this because it is adjustable from 85mm to 130mm but I would adjust it around 90-100mm probably.
Thanks.
Andy
· mreow
What you need to compare is not the travel, but the axle-to-crown lengths of your current fork and potential replacement, as a change in this length over 10mm or so will significantly change your bike's geometry and handling characteristics. Yes, it could be a safety concern as too long of a fork would put added stress on your frame's headtube.
I upgraded my old 65mm fork to an 80mm fork, but the axle-to-crown lengths were barely 1mm different, so there was no change in the bike's geometry.
1 - 2 of 2 Posts
