1 - 6 of 6 Posts
Recently built up a Vicious Cycles Fat Sheeba with a 100mm White Industries hub. Ran into issues fitting into a 29er fork running Surly Larry tires.
What options are out there for 100mm fat forks to fit 26 x 3.7 other than a Surly Pugsley fork?
Wildfire forks are also 100 mm and will fit an 80 mm rim/Larry combo. Wildfire's website recently was taken down, but maybe if you called them directly they would sell you one. Several other custom builders (including Vicious Cycles) will make them.
1 - 6 of 6 Posts
