This is a bike I’ve building for a while. The scale is 10.36lbs.on a certified calibrated scale These components were chosen for performance and functionality. The carbon rings are not made for longevity, it’s just my opinion I’m pointing out the carbon chain rings on the list are only made to last 4 or 5k miles. This is my second pair of rings, my old carbon rings had about 4500 miles and none of the teeth have broken. I had changed them because of the wear.
I do not recommend some of these light weight parts if you are over 165lbs, these very light weight parts are only made for light weight riders the carbon rings are made by tune, are the best they are thicker than the normal carbon ring. Currently these rings have 900 miles on them They do last for about 4k to 5K miles. They do shift very well and as far as areo light pedals, in my opinion the pedals are easy to get in and out of. The best pedal for what they are I have tried many clipless pedals and I like the areolites the most. I have tried many pedals (Speed play X 1,to much float\time Atac carbon Ti to sticky to get in out of also the bebop deluxe to hard to get in and also to much float.
Thank you for all your opinions and input.
Here is my components list.
scott cr1 w/cable guide & screw 890g
Scapula SP Carbon Fork 220g
SeatClamp 14g
Ti,BB,w/ceramic bearings & Alum bolts 130g
SeatShim 20g
Seatpost New Ultimate 94g
Saddle 46g
Headset 82g
Topcap 2g
storck Crankarms 320g
Both Tune chainrings & bolts 90g,Areolite Pedals 72g
Carbon Schmolke 40cm Bar 135g
Syntrace Stem w/ti bolts 91g
Brakes Zero Gravity w/btp carbon pads 159g
One piece Alum cassette 106w/lockring Tune Skewers 54g
Ti chain 240g
Front derailleur Record Carbon BTP 55g
Rear derailleur Record Carbon 185g
Shifters & brakelevers Record w/btp clamps 304g
Brake Cables 75g
Shifters Cables 84g
Bartape 50g
Frontwheel W/reynolds cirro sv-kom carbon rim AC mirohub 380g
Rearwheel reynolds cirro sv-kom carbon rim W/tune 160 carbon hub 506g
Both tufo tires elite jet 320g
Grease & misc.19g
Total 4738grams
SeatClamp 14g
SeatShim 20g
Saddle 46g
Headset 82g
Topcap 2g
Ti chain 240g
Brake Cables 75g
Shifters Cables 84g
Bartape 50g
Grease & misc.19g
Total 4738grams
