Anybody using a 1 x 10 set-up? Thoughts, ratios please?
And you forgot the bashgaurd as well :thumbsup: Thats another 90+ gramsrscecil007 said:Damn, I forgot about the Granny and bolts. Probably another 30g or so there.
I find varying weights on the XT 11-36 cassette as well. Some sites say 286, some say 335. Anyone actually weighted one?
Wow, I am really off and not with it today.climbingbubba said:And you forgot the bashgaurd as well :thumbsup: Thats another 90+ grams
The weights im going off of for the XT cassette is from bti. It says the 11-32 is 285 and the 11-36 is 350 or so.
If the weights on BTI are correct then the Sram 1070 is cheaper and weighs 85 or so less grams then the XT. Would be great to know the actual weights....
To convert to 1x10, I think you just need cassette, der, chain, & shifter. I think you can keep same front ring. May be different if you are going more than one front ring like 2x10 setup...loamranger said:So you don't need special 10 speed crankset rings, is that right?
In that case I could fit some Renthal rings to my Saints?
FYI, I ordered all that from ebikestop.com, they were the only ones i found that had the MRP mini G2 SL in stock, and the pricematch all the other stuff. The only thing they didn't was the XT cassette, but they knocked it down to $74.99. The KMC chain my buddy is ordering me 2 when he puts in an order from Ribble over in the UK in the next few days.loamranger said:rscecil007, sensible build, I may copy? What are the pros and cons between short and medium cage?
Not as much as the Knolly, but there are more than a few rides in the area for which the Delirium is a bit overkill...Chromagftw said:CLAW does your Sov still see much action?![]()
