I guess this is a volume spacer question. I have 2016 Fox 32 @ 120mm and it came factory installed with a volume spacer. I've had a hard time getting the fork dialed (some of which is a result of also riding a sweet, plush 140 Pike).
It's been a little harsh and I've had a hard time using all of the travel. I've experimented with taking out air pressure, but it eventually starts to not sit very high in its travel, even if it doesn't bottom out. Will adding another volume spacer allow me to run less air pressure but still keep the fork sitting high?
On the other end, I removed the air token and ran it without, but found I had to run a lot of air pressure to keep it from bottoming.
Is the moral of the story that volume spacers allow for a little less air to be used and keep the fork a little more cushy, but won't miraculously transform an XC fork into a trail fork? And/or is the moral that I should get a 120 Pike?
