1 - 15 of 15 Posts
My front tire is a specialized captain control with homebrew (WSS) tubeless sealant. I've read about people sewing up tears, and I've used patches to fix holes in my tread. This is my first sidewall issue, can I salvage the tire?
I'm a big fat fatty at 250 pounds, so I'm concerned about the flex of the sidewall if I just patch it. Right now I'm running a tube and milk jug boot until I figure out a permanent solution.
Thanks all
Banned
A couple of stitches with dental floss and a boot patch has worked for me in the past at a similar weight.
plus 1 for the chongoman.....HEY ajmelin ~You can certainly patch that from the inside. clean and sand (ruff up) the inside of the tire at the wound. then smear in the rubber cement and let dry. apply the patch normally and use a quality, (not walmart!) patch that is 1-1/4 inches in diameter or larger. rub the patch like crazy to make sure it stays put.
now for the secret. sand and ruff up the patch you just installed. then glue and apply a second patch on top of the first one. WHY? you need the extra thickness to keep your tire from blowing a bubble with the first patch.. a larger slice might need a third patch. i have saved more than one tire this way. best-o-luck! :cornut:
I use a rubber auto patch and gorilla glue, ...works like a champ , put it in a vice for acoupple hrs and it never moves .
I could not keep any Specialized "control" series tire sidewall alive for even one ride tho, they did not like pounding through the chunk .......they are light but also alittle week .
Rhino
Thanks all
I use the Captain. They have smooth side walls. I clean mine with Goof Off and just use a bike patch. They lasted well over 200 mile bikeback trip with out any issues. Never used the car patches, seems like a good idea, but the bike patches worked for me and are cheap and available.
Discussion Starter · #9 ·
Awesome feedback everyone, thanks!
Like I said, I've patched similar holes in the tread area, just not inthe side wall. I like the patch over a patch idea. I'll give that a go, and clamp it overnight. Hopefully I'll be able to ride tomorrow!
I clean off the tire sealant with acetone and use motorcycle size slime brand patches. Be careful not to sand to aggressively. I got caried away on a Maxxis Ignitors once and the casing ended up bulging around the patched area.
skilldest©
Similar, I would get small tears, then would put a boot inside with tube to keep going. Then at home patch from the inside. Gets lame to keep fixing them. I tore a captain control 2bliss riding UP the fire road on somo. Gosh darn it!
Black and Sticky
Park Took Emergency Tire Boot
I have had great success with the emergency tire boot, which you can buy at just about any LBS plus REI. Clean the torn area with rubbing alcohol, acetone, or similar, sand very lightly, and then apply the boot. Cheap, easy, quick, and extremely effective for a tear as small as you indicate.
Park Tool Co. » TB-2 : Emergency Tire Boot : Tube & Tire
Bob
I have had a couple of torn sidewalls. The method that I use is to stitch up the tear and then apply tube patches to the inside of the tire. Every torn that I have repaired has required at least two tube patches to cover it from the inside. Also, when you stitch the tear make sure you dont get too close to the edge of the tear. I would go at least 1/8th of an inch out. Stitching is essential to make a repair last. I have gotten full life out of repaired tires.
dirt visionary
I tore the sidewall on my single ply minion on shultz...Had no more plugs and it was a good lil slice...Took my knife and cut a strip off my sock stuffed it in the hole . Been good ever since lol and thats been around 4 months not ideal but got me off the mountain without having to pull out the tube and dealing with the mess.
1 - 15 of 15 Posts
