I'm going to be sprucing up my neighbors bike for him including replacing (or helping him to replace) his messed up FSA 1.5 headset. I can craft up a pretty decent press for installing one back in his frame but that leaves me with the problem of getting the present one out. I don't think that fluted punch that you normally use for 1 1/8" headsets is wide enough for the 1.5" headsets - am I wrong? I could try bending the flutes a little bit outwards but with my luck they'd contract a little bit before I hit it with the hammer and shoot it out the other side of the headtube and across the room, but anyways...
Is there any safe and reliable "ghetto" method to removing a headset? My next best idea would be to find some sort of a punch and lightly tap around the innermost lip of the headset in the same way you would use the fluted tool. I wouldn't want to scuff up the contact surface for the press fit surface on the headset cups though. Any other suggetions?
I'll also be checking to make sure the douche REI employees who haphazardly built his bike to begin with faced the headtube and BB - are the facing tools for a standard size headtube wide enough to be used with a relatively thin 1.5" headtube? I should probably mention that this work is going to be done on a Gemini with an FSA 1.5 headset and a Sherman fork.
