I have yet to own/work on a bike with a 1.5 headtube. Are all forks still 1 1/8"? Is the idea behind the headtube a larger bearing or to recess the headset cups or both?
nope......manitou makes the single crown travis in a 1.5 steer tube and some of the sherman's have 1.5 steer tube also you can get rockshox totem's with a 1.5 steer tube:thumbsup:shmokinjoe said:Are all forks still 1 1/8"?
fortunately not many are jumping on the badwagon, there is no advantage to use a 1.5" Cannondale has been doing it for agesshmokinjoe said:I have yet to own/work on a bike with a 1.5 headtube. Are all forks still 1 1/8"? Is the idea behind the headtube a larger bearing or to recess the headset cups or both?
Don't you mean "Solution in search of a problem"?Jersey said:...problem in search of a solution...
There is a distinct advantage to using a 1.5" headtube that manufacturers are only recently discovering, but not what you would expect. While the 1.5 steerer was originally marketed to freeriders touting greater strength, it never caught on for that reason. Dirt bikes use 1" steerers, and go 100mph and jump 100" gaps. The steerers are thick, heavy steel.Davide said:fortunately not many are jumping on the badwagon, there is no advantage to use a 1.5" Cannondale has been doing it for ages
Probably depends on the headset. I know with with at least some of the FSA 1.5s you just switch a couple parts and it becomes a 1.5 to 1.125 reducer headset. Nothing needs to be pressed out.shmokinjoe said:So if I buy a bike with a 1.5 I will need a headset that will have a 1 1/8 steerer tube diameter? and If i upgrade to a 1.5 fork then I'll need a different headset, correct?
It is not 1.5" headtubes, the fork steer tube is 1.5". This means the frame's HT needs to be larger to fit the larger diameter headset and fork steerer. There are headsets designed for using 1.125" steerer forks in 1.5" frames (along with the spacers others have mentioned.shmokinjoe said:I have yet to own/work on a bike with a 1.5 headtube. Are all forks still 1 1/8"? Is the idea behind the headtube a larger bearing or to recess the headset cups or both?
Shiggy's right..Although in the Cdale case my steerer tube is 1.562" in diameter, and I think 1point5 on regular bikes IS 1.500"....shiggy said:It is not 1.5" headtubes, the fork steer tube is 1.5". This means the frame's HT needs to be larger to fit the larger diameter headset and fork steerer. There are headsets designed for using 1.125" steerer forks in 1.5" frames (along with the spacers others have mentioned.
The 1.5" (one point five) "idea" is have a stronger/lighter/stiffer single crown long travel fork.
I really doubt you will see any weight gain. There is always a little tiny problem with the "equation" larger diameter=thinner walls. The problem is that you cannot decrease wall thickness below certain limits and as a result you end up with a bigger AND heavier component. Just look at handlebars: the new 31.8 bars are heavier then the corresponding 25.4.Kracker said:What engineers have found recently though, most notably at Rockshox, is that for a given tested target stiffness, they can make their products lighter by using a 1.5" steerer. We should not be surprised at this, given that we know how larger diameter thinwall aluminum can be made lighter than smaller diameter tubes with thicker walls. Klein, and ironically Cannondale, first showed us this in frame design many years ago.
So if you'll reread my post, you'll see that what I'm saying is that, while you are correct that going bigger/thinner EVENTUALLY runs into a wall, we are not there yet with mtb steerers. 1.5" front ends can be made lighter than their 1 1/8" counterparts FOR A GIVEN STIFFNESS.Davide said:I really doubt you will see any weight gain. There is always a little tiny problem with the "equation" larger diameter=thinner walls. The problem is that you cannot decrease wall thickness below certain limits and as a result you end up with a bigger AND heavier component. Just look at handlebars: the new 31.8 bars are heavier then the corresponding 25.4.
As you mention if you are using a double crown fork you could easily get away with a 1" steerer (like motorcycles do), and if you really want more strength for a single crown you can go stronger aluminum or steel (like Marzocchi). I don't think Marzocchi has problems with strength and I would be surprised if a 1/8" steel steerer is not stronger then a 1.5" aluminum.
