Your brakes have air in them and need to be bled correctly, they just come like that from the factory sometimes. They're great brakes if set up and bled right.ir12daveor said:Don't get either. They suck.
They are really a pain to set up, they constantly rub, modulation changes for no reason. Oh and they will sometimes just pull straight to the handlebar on without activating on long descents.
Also they are more expensive then Shimano XT's.
I got Juicys as part of the build kit on my bike and can't wait to change them, I don't trust them.
My brakes have been bled numerous times. They might work cross country but definitely not all mountain, and the setup is still a pain in the a$$. I'll admit I'm a perfectionist who hates the slightest little bit of noise from my brakes, but My Shimano's on my last bike worked a treat.CoryBike said:Your brakes have air in them and need to be bled correctly, they just come like that from the factory sometimes. They're great brakes if set up and bled right.
sounds like your mechanic is the issue..ir12daveor said:My brakes have been bled numerous times. They might work cross country but definitely not all mountain, and the setup is still a pain in the a$$. I'll admit I'm a perfectionist who hates the slightest little bit of noise from my brakes, but My Shimano's on my last bike worked a treat.
I'm not the only one reporting these problems, 5 out of the 7 people I ride with who use Avids have similar problems, not all the same year or batch or brakes either so its not a faulty batch.
One of my mates had to constantly pump his brakes to have any braking power in a race last week, his brakes had been professionally bled. Another had the bar pull to the lever on a rocky descent high up in the alps. I've seen so many failure issues with these brakes.
