1 - 6 of 6 Posts
not actually bad :)
I bought a new '08 Mongoose Canaan Comp about a year ago.
Have been enjoying it, and it does what I need it to!
The pivots are starting to creak. Is there any maintenance I need to do?
Or just replace them, or??
Any help?
not actually bad :)
Discussion Starter · #3 ·
mullen119 said:
http://www.mongoose.com/usa/usaeng/mtn/tech
Check that out. It gives decent information about maintenance. Check you bolts are tight. you might need to replace the bearings in the pivot behind the BB.
Thanks for the link.
That's perfect.
I took the main pivots out and greased them up as specified. That helped a ton. Still need to get to the other ones as there's still a little creaking, but 95% better already!
:thumbsup:
1 - 6 of 6 Posts
