1 - 14 of 14 Posts
Ferdball
My shock looks similar lot of what I would call excess oil on it. Took it back to the LBS who looked and said keep and eye on it.
I thought it was too much, but not sure how 'wet' an air shock runs? Mine seens to be more than the others I ride with. If it becomes a real problem then I will ask nicely for a new one.
Also noticed that my RP2s custom tune bit is the middle compression bar, yours being on the small guess they really do custom tune them!!!!
Laters
Dom
Firstly clean the damn thing!!!! excess dirt like that can find a way under seals and car damage your shock.
as for the leak - the fox floats do run with the shaft lubricated, i wouldnt worry to much untill you see it dripping onto the floor thats when u go "aww S&%#" i really wouldnt worry about it but keep it clean!
WooHoo Biking!!!!
I have an RP23 and oil residue appears on the shock body after I ride, especially in the heat. I contacted Fox to see if it is normal. They said that it is okay for a little oil to appear and to clean it off after each ride. They also said that you should start worrying when the oil doesn't appear after a ride.
Titanium Club
Discussion Starter · #7 ·
So, is there a maintenance schedule where we have to eventually add oil to the shock?
G
I know I'll hear s%&+ for this, but I add oil every few rides by "injecting" a few drops under the seal (use an old Triflow bottle filled with suspension fluid with the hose cut at a 45° angle). Works like a charm.
Titanium Club
Discussion Starter · #12 ·
goodvibe said:
If you click here, you can see the service intervals posted by Fox.
http://www.foxracingshox.com/fox_tech_center/owners_manuals/08/eng/2008_om_eng.htm
So, authorized service is needed every 100 riding hours. I didn't realize that I'd need to pay a shop to service the shock every year. For reference, I never had my 04 NRS1 serviced and it never leaked.
I cleaned the bike and will ride it for a bit. I'll see if it leaks more or less than before. If its more, I'll be taking it in to Trek for a look.
1 - 14 of 14 Posts
