1 - 7 of 7 Posts
damper
The 5wt will be ok. But, the best set-up is to use a 50/50% of 5-10wt and Sram Red Rum of Fox Float Fluid. This will give better lubrication for the bushings but not be quite as thick as straight Float Fluid. 12ml is good for a bigger rider or if you want a more progressive ride.
Discussion Starter · #3 ·
Problem with reinstalled damper
After reinstalling the damper the rebound adjustment knob jumps up on every compression of the rear end causing a very audible click. You can see it clearly by standing off the bike and cycling the suspension. The knob jumps up as the suspension compresses and then seats back down when it extends. The damper is definitly seated properly all the way down in the shock body and the set screws are torqued down correctly. I disconnected the top shock mounting bolt, removed the gold rebound adjustement knob, and bolted it back on. With the gold knob removed you can see the gap created between the top nut and the top of the damper when it is compressed. i have no idea what I did wrong:confused: I have awesome help from Anthony at my LBS. He will have it apart tomorrow for a look. Anyone have any ideas?
mine is now making a "clacking" sound when it goes just below the sag position and back up :skep:
i've checked the monolink bearings, everything there seems to be ok - the noise is "definately" coming from around the shock body area ...
i guess i'll have to take it out and have a look :incazzato:
ragetty
well, i didn't have to go that far ...
it turns out i have *exactly* the same problem as JTP, but in my case the shock wasn't even removed, the issue just "appeared" during a ride - i just retried seating the rebound knob, but it has made no difference ...
ragetty
1 - 7 of 7 Posts
