Have you wrecked at caused the bar to spin around and jam the damper controls into the downtube? I've done that before and I had similar behavior to what you describe.simplton said:I've got an '07 TALAS RLC and the lock out lever is binding. When I turn the lever, the compression adj. knob also turns. Any ideas? I hope so, this is startin' to pi$$ me off.
cheers,
simp
My '06 fork behaves the sdame way since new...compression knob spins with lockout (when you engage it) but does not spin back when you disengage it. I assumed it was a goofy "feature" and not a mechanical problem. The action ofthe lockout lever itself is very smooth though...so if you have a binding feel then there may be something else going on with your fork.simplton said:I've got an '07 TALAS RLC and the lock out lever is binding. When I turn the lever, the compression adj. knob also turns. Any ideas? I hope so, this is startin' to pi$$ me off.
cheers,
simp
Yeah, that's exactly what mine was doing. I eneded up taking off the rebound dial, loosened up the three 1.5mm allen lock screws on the lockout lever, and lifted off the lever. I cleaned everything up and replaced the grease that was there from the factory with some very light silicon grease and reassembled. Things seem better now. I think the grease from the factory was causing some friction and the three locking allen screws may have been a bit tight.05stumpy said:My '06 fork behaves the sdame way since new...compression knob spins with lockout (when you engage it) but does not spin back when you disengage it. I assumed it was a goofy "feature" and not a mechanical problem. The action ofthe lockout lever itself is very smooth though...so if you have a binding feel then there may be something else going on with your fork.
Cool man. Good luck. Like I said, it's still not perfect, but certainly better than it was...05stumpy said:good info :thumbsup: , glad to see Fox has some proper servicing info available now...it was all a big mystery in '05!
I'll have a look in there and post if your suggestion helps.
