I had an 05 racer-x but didn't have this problem. Recently got an 07 and now I'm having issues with the chainline. When in the middle ring, shouldn't I be able to get into the low gear on the back (the easiest gear)? When I try to climb in the middle-low combination, the chain isn't happy and makes sounds like it's popping off. I don't have issues in the stand, or on flats...only when climbing. As a result, I dropped the chain down to the granny and used 3rd lowest to get a comparable gearing while climbing. I suppose I can learn to deal with this, but I never experienced this at all on my old racer x. I did have to face my BB shell on the old one (came in at 74.3mm...WAY out of spec). This one was faced and chased by the factory...a nice job, and comes in at 73.2 mm...close enough.
Here's a possible solution I thought of. When I look closely at in and take a few measurements, I noticed that the drive side probably has about .5mm more metal on it than the non-drive side. This is all referenced from the seat tube. Since the shell is pretty much in tolerance, I don't want to remove more metal. I've got RF deus cranks, and the install requires a 2.5mm spacer between the outboard drive bearing and the shell. I didn't put any sort of spacers on the crank, which allows for chainline adjustment...making it have the most inward chainline as possible. Here's the thought I had...I could remove additional metal on the BB shell and make the shell 68mm. If 68 mm, I'm supposed to use 1 x 2.5mm spacer on the non-drive, and 2x2.5mm spacer on the drive side. Since I'm removing metal, I can actively try to remove just a bit more on the drive side to push the chainline inward. So...what do you all think? What should I do?
