I'm struggling with a brake noise issue with my new juicy 7 brakes. I have 185mm juicy 7 brakes front and rear on my bike. The rear is an 06 brake with the polygon style rotor and the front is an 07 brake with the new generation 2 clean sweep rotor. Under light to moderate braking the clean sweep rotor makes a lot of noise. It is a sort of squealing/howling resonance that is loud! As in wake the dead loud! I believe this issue is related to the clean sweep rotor because the I tried swapping the rotors front the rear and the noise moved with the rotor. I've tried cleaning the rotor with alcohol and scuffing the rotor and pads with sandpaper to no avail. I've also experimented with putting spacers under the caliper to shift the brake pads slightly relative to the rotor, also without success.
Does anyone have any suggestions?
Thanks,
Mike
Thanks,
Mike
