1 - 20 of 47 Posts
'18 Transition Sentinel
Yes, here's another "Here's my BR!" post...:blush:
My backordered frame finally arrived last Friday, picked up the last couple of parts on Tues, then went out for the 1st test ride on Wed - sweet! :thumbsup:
Since my "raw/small" frame came in the same batch as the new '08 Baby Blue ones, is my "raw" frame considered as an '08, too...? :skep:
Also, starting with this batch, the "raw" comes clear-coated now (so I guess it wasn't before?), per folks at Transition, just FYI.
Anyway, below are some pic's.
My "small/raw" frame (including a drlr hanger, 2 shock-mounting bolts, 11 plastic cable-guide pieces) read "8lbs 3oz" on the scale. Everything put together read "41lbs 12oz" on the scale.
As for parts, nothing fancy - just moved everything from my old bike (broken). Actually, there's one tiny thing that's fancy - the TBC bar-end caps! ;) Maybe I'll pick up Juicy 7's later on (no rush).
Cheers,
- PiroChu
Discussion Starter · #2 · (Edited)
Some more pic's...
And here are some more pic's...
Very excited!! Now I gotta go ride (& tinker with the rear shock a bit) and have fun!
Cheers,
- PiroChu
PS.
For fully-extended seatpost for climbing, I'm only 4mm above the "minimum insert" line. Before purchasing a BR, I knew I'd just clear it, but that was kinda close... ;)
Discussion Starter · #6 ·
ban said:
which reducer did you pick at the end??
ban,
Thanks for asking. After some thoughts per my other post about a headset earlier, I ended up getting a FSA Orbit Z 1.5R after all.
I got the cups pressed in at a reputable LBS, and they faced/reamed the headtube in the process, too, which was nice because my "raw" came clear-coated. They said lots of coat came out of the headtube.
Cheers,
- PiroChu
okay PiroChu, I have finally ordered a Sunline headset reducer and it seems to be a PITA to install so I was going to ask you your advice in case you bought the Sunline as well....BTW niiice Bottlerocket!! Im waiting a baby blue to arrive home this week and I cant hardly wait to have it built and ride it!!:thumbsup: :thumbsup: :p :p :thumbsup: :thumbsup:
PiroChu said:
ban,
Cheers,
- PiroChu
Discussion Starter · #9 · (Edited)
Spec List
Forgot to post this spec list earlier, just in case anyone's interested...
- PiroChu
[Total = 41lbs 12oz]
'07~'08 BottleRocket small frame (8lbs 3oz, incl. drlr hanger, 2 bolts, 11 cable guides)
'08 Fox DHX 5.0 coil shock 7.875"x2.25" (386g/body&DU&bumper&retainer) plus 400lbsx2.45" spring (333g/coil) plus Fox reducers + custom-cut PUSH 22.8mm/M8 reducers (3g/each) = 731g
'05 Marzocchi Z1 FR I fork (HSCV & Air Preload & ETA) 150mm = 5lbs 7oz (220mm steertube, 45mm oil height, 7.5wt Maxima fork oil, including starnut/10g & headset race/15g) + 20mm thru-axle (86g)
optional Marzocchi integrated fender (62g = 54g/fender + 4g/bolt + 4g/bolt)
FSA Orbit Z 1.5R headset (1.5" to 1-1/8", 10.7mm total stack height)
generic headset spacers
Avid CPS mechanical disc brakes: 203mm/front (233g/rotor + 14g/6bolts + 52g/adapter + 10g/2bolts) & 160mm/rear rotors
Avid SD-7 levers (88g/each)
Avid Flak Jacket brake cable set (5mm housing, 920mm/front + 1360mm/rear)
Avid Straight Jacket derailleur cable set (4mm housing, 38"/front + 58"/rear)
Shimano XT FD-M751 front derailleur (34.9mm) = 137g
SRAM X.9 rear derailleur ('medium' cage) = 235g
SRAM X.9 trigger shifters = 252g/pair
SRAM PC-971 chain (1/2 + 50 + 1/2 links length)
Shimano XT FC-M751 crankset (44-32-22T, 104mm/64mm, 4-bolt, with 175mm arms)
Truvativ TruShift 22T 64mm steel ring (37g)
Truvativ TruShift 32T 104mm steel ring (79g)
Truvativ RockGuard bash guard (4-bolt/104mm), 142mm (5 3/4") diameter, 10mm-thick Lexan polycarbonate = 99g/plate + 28g/bolts = 127g
Truvativ Shiftguide chain guide = 309g
Shimano XT BB-ES71E bottom bracket (73mm x 118mm, E-Type) = 266g
Shimano XT CS-M760 cassette (11-12-14-16-18-21-24-28-32T) = 262g
Weyless B-27 platform pedals (250g x2)
Race Face Diabolus stem (50mm, 10-degree, 25.4mm clamp, 1 1/8" steer) = 245g
Race Face Riser Bar (Air Alloy, 28", 25.4mm clamp) = 345g
ODI Rogue Lock-On Grips with Transition bar-end caps = 144g
Truvativ XR Double Clamp seatpost (30.0mm x 350mm) = 305g
Salsa Flip-Lock QR seatpost collar (34.9mm) = 44g
WTB Power V DH Race saddle (152mm x 307mm) = 379g
Sun Single Track 36H rim + Hadley front disc hub (110mm spacing) + DT "Champion" 14 (2.0) spokes + DT standard brass nipples = 1072g/front
Sun Single Track 36H rim + Shimano XT FH-M756-L rear disc hub (135mm spacing) + DT "Champion" 14 (2.0) spokes + DT standard brass nipples with XT skewers (64g/rear) & 3M strapping tape = 1360g/rear (all included)
Kenda Blue Groove 2.35 tires (DH wire casing, 60tpi) = 1176g & 1186g
Hutchinson Green DH Tubes (26" x 2.0"~2.5") = 366g & 374g
VDO MC1.0 cycle computer with altimeter
may I join ?
Thats a solid build ! I really like raw (works finish ?)
Could not hold myself frm posting mine up ! jst after light washing & installing new pedals = straitline (X-ray color). Now ordering frame decals (white) frm TBC & will update post once sticked !! Mines without clear coat. I guess 08 raw models come with clear coat which is nice. enjoy ! :thumbsup:
Discussion Starter · #16 · (Edited)
.Danno. said:
Do your fork knobs clear the downtube with the zero stack HS?
Hi .Danno., I just went to measure mine. My fork ('05 Marz Z1 FR1) has taller knobs (than HAB's 36), but the distance at the closest point between downtube & knob still has about 5/8" of clearance. :thumbsup:
Hi freeryder, thanks for your info on "no clear-coat for ~'07/raw". I guess I can consider my "raw / clear-coated" as an '08 then. :)
Discussion Starter · #17 · (Edited)
MattP. said:
Can't really make out the scale, what is the weight?
Hi MattP., yes, I know, it's hard to make out the digits in the pic. It reads 8lbs 3oz, and please note that this figure is for a "small/raw" frame including a drlr hanger & 2 shock-mounting bolts & 11 plastic cable-guide pieces, per my original post. The Transition website says "8lbs 1oz" (probably without the little pieces I measured mine with), so it's pretty much dead-on.
PiroChu said:
Hi MattP, yes, I know, it's hard to make out the digits in the pic. It reads 8lbs 3oz, and please note that this figure is for a "small/raw" frame including a drlr hanger & 2 shock-mounting bolts & 11 plastic cable-guide pieces, per my original post. The Transition website says "8lbs 1oz" (probably without the little pieces I measured mine with), so it's pretty much dead-on.
Very nice! Appreciate the explanation!
Matt
Freeryder, where did you get that saddle ? Is it an SDG ?
Hey, you know what sounds deadly on a BR for 08 ? Marzocchi 55 & Roco TST Air. Smooth and light.
The 55 is a Z1/66 hybrid (perfect). I wonder if the Roco air is user servicable ?
& U gotta love that raw is being sold as "works"
1 - 20 of 47 Posts
