kbahus said:
Mine is the retail version, no air on the eta side. It is starting to break in and feel much better. I am currently running 1 click of compression and not sure on the rebound but it I am finally starting to get the feel I want. Dropped some air pressure as well.
So I played with my fork a bit and with 5psi in either the left or right side I get 23-25mm sag. With no air and 4 clicks of compression I get 33mm of sag which is only 22% but it bottoms out. So I've gone with 1 click of compression with 5psi and the ride is pretty good but I don't use all the travel. I wish I had a pump that could measure small increments instead of a 300psi shock pump. The manual says to play with oil height as well but I have no idea where the information on oil height for this fork is on their web site.
5.2 Spring Preload
The best spring preload is the one allowing you
to obtain the desired SAG point due to the
rider's weight (SAG) (see par. 5.4 SAG).
The preload spring may be adjusted, depending
on the model, through mechanical adjusters or
with pressurized air inside the fork's leg.
On the models provided with mechanical
adjustment, each adjuster turn corresponds to a
1mm spring compression.
5.3 Positive Air
The positive air is the elastic factor for
air forks.
The best positive air pressure allows you to
obtain the desired SAG (see par. 5.4 SAG).
Rider weight 120-155 155-180 180-210 210-220
Positive air pres 30-40 35-45 42-52 52-65
Preload air pres 0-15 0-15 0-15 0-15
