1 - 10 of 10 Posts
Hello
I'm planing to buy this fork, and my weight is 165.
Does the original coil fit to my weight ?
Thank you
Fragilie
alonfo said:
Hello
Thank you
I would say so as I'm running it and I'm 190 with gear. I wouldn't mind a bit stiffer so I would say the stock spring should work well for you.
In exile
The Z1 Light is adjusted up with air pressure, but running 38 lbs or so at 210 with gear, all is cool. You'll be more than fine.
carpe mañana
That looks good. At 165 you'll probably be perfectly sprung with 0 air in there.
_MK
In exile
Nice ride, but I don't agree that 0 air is the right choice. That's just my opinion though. I can't imagine that I need over 35 lbs of air to make things right when I weigh only 35 lbs more. It just doesn't make sense to me.
Discussion Starter · #9 ·
agree. run it with 25Psi with the compression almost open, and after one ride in local DH course with alot rock gardens - it fills geat ! far way better then the 36 talas. very plush, but still progressive and dosent buttom out. I'm very pleased.
No additional springs is not true anymore.
Marzocchi does now offer softer springs. I have bought a set of them, labeled with Marzocchi Sticker and all. Come as Z1/DJ/AM Soft Spring kit Marzocchi....
I have them in my Z1FR1. They only come for the rebound side. So they are still a little too stiff for me, I am only 148lbs though.
greetings Znarf
1 - 10 of 10 Posts
