Has anyone experienced the same problem? Or is the problem small size frame specific?
The '05 Nixon clears my medium frame... could be an issue with small frames. Anyway, for a solid solution you could run a higher stack headset. For King headsets, Ventana makes a nice 4mm or 7mm crown race.StabbedDawg said:Has anyone experienced the same problem? Or is the problem small size frame specific?
Thanks Sus,sus13 said:The '05 Nixon clears my medium frame... could be an issue with small frames. Anyway, for a solid solution you could run a higher stack headset. For King headsets, Ventana makes a nice 4mm or 7mm crown race.
Headset:
http://www.canecreek.com/s3_plus_5.html
King crown race:
http://www.competitivecyclist.com/z...TANDARD&PRODUCT.ID=3120&CATEGORY.ID=469&MODE=
I'll bet you will have no problem ordering direct from Ventana on the web, from that link I sent you. But as I said I think your problem will be solved with a non-zero stack headset like a Chris King.StabbedDawg said:Thanks Sus,
Ronnie helped me via email about the headset. I'm going to buy the CaneCreek headset for now since Ventana things are really hard to buy in Japan especially the small parts.
:thumbsup: I sold you .Mac! I should be awarded by Applescruffylooking said:Wow, I had you pegged as a westerner in Japan. I was totally wrong!BTW, your photography is sharp, your garage is nice, and the bikes rock, too. I'm going to have to consider .Mac now.
Oh, and I'll stop gushing, too.
Never thought of that. Good idea.hammerheadbikes said:you can take any race and grind the lip off it, nice and flat, and put it under the race...
a king race ends up being 3mm
done it numerous times
I already got the Ventana crown race.StabbedDawg said:Never thought of that. Good idea.
Hi, I was just wondering if you got your ventana race sent from the US? I live in Thailand and i have the same problem. We can't really get any Ventana stuff out here. Can you advice me on how you got yours? You help would be most appreciated.StabbedDawg said:I already got the Ventana crown race.
Here's the photo.
Only draw back of plus 7 mm crown race is its look.
It looks like fork is coming off from the head.
For that reason, if one can solve the conflict with adding 5mm then Can Creek headset might be a better choice.
Hi, I got the Ventana Crown Race, King Headset from one of the sponsor of this site, Competitive Cyclist. It arrived in two days from Arizona to Japan. Just amazing.Tayancycles said:Hi, I was just wondering if you got your ventana race sent from the US? I live in Thailand and i have the same problem. We can't really get any Ventana stuff out here. Can you advice me on how you got yours? You help would be most appreciated.
NP. Yes, ordered on their site. What a great webshop to have the particular parts in stock to begin with, and the service was super fast.Tayancycles said:Thanks stabbeddawg. So did you just ordered it off the web and sent to Japan? BTW cool blog you got there! Are you a graphic designer?
Thanks! I'll keep you posted. I think you can still take credit for your site. A tool is as good as a tool without a creative user. Your photos are great! keep up the good work.StabbedDawg said:NP. Yes, ordered on their site. What a great webshop to have the particular parts in stock to begin with, and the service was super fast.
Thanks about the blog, but most of the graphic is coming from the template of iWeb for Mac, I will take the compliment if you tell me my photos look nice.
Hope you solve your problem with Comptetitive Cyclist.
yes, you canpeachy-B said:grinding is not going to give u a perfectly flat piece, unless you're using a tool grinder (machine shop) but i'm assumming you're not. sorry but that doesn't sound like a good idea. the race needs to be bang-on perpendicular to the steertube. isn't that the main reason for facing the headtube?
