Can any of the '06 owners comment on rear tire clearance? I know on the older models you were hard pressed to get anything over a 2.35" to fit without rubbing.
06 Flys wont be shipped for about another week. The tire clearance should be the same as all the Flys. All 2.35s and SOME 2.5s.Surfinguru said:Can any of the '06 owners comment on rear tire clearance? I know on the older models you were hard pressed to get anything over a 2.35" to fit without rubbing.
A Gazzi 2.6 fits fine.Surfinguru said:Can any of the '06 owners comment on rear tire clearance? I know on the older models you were hard pressed to get anything over a 2.35" to fit without rubbing.
On what year FLY? The 2.5 Maxxis barely fits on a 321 rim.drdualee said:A Gazzi 2.6 fits fine.
I own an 05. If you actually put calipers on the Gazzi its only a 2.5, mine is mounted on a Mavic 729 rim. Too bad tire manufacurters don't size their product to an international standard . Instead we're left to discover on our own, for example, that a Gazzi 2.6 really isn't a 2.6 but a 2.5, however, the new Kendas ( Tomac Series only not the Kinectics), is actually the advertised size. Etc, etc. Rediculous!kanter said:On what year FLY? The 2.5 Maxxis barely fits on a 321 rim.
I run either a Maxxis Minion 2.5 or a Kenda Nevegal 2.35 DH in the rear of my Fly. The Kenda 2.35 is the same size as the Maxxis 2.5!!!!drdualee said:I own an 05. If you actually put calipers on the Gazzi its only a 2.5, mine is mounted on a Mavic 729 rim. Too bad tire manufacurters don't size their product to an international standard . Instead we're left to discover on our own, for example, that a Gazzi 2.6 really isn't a 2.6 but a 2.5, however, the new Kendas ( Tomac Series only not the Kinectics), is actually the advertised size. Etc, etc. Rediculous!
i have an 05 frame and run 2.7 maxxis highrollers on it, which are plenty thick enough. i cant fit anymore with the floater but im pretty sure theres room to go bigger if you didnt have the floater.drdualee said:I own an 05. If you actually put calipers on the Gazzi its only a 2.5, mine is mounted on a Mavic 729 rim. Too bad tire manufacurters don't size their product to an international standard . Instead we're left to discover on our own, for example, that a Gazzi 2.6 really isn't a 2.6 but a 2.5, however, the new Kendas ( Tomac Series only not the Kinectics), is actually the advertised size. Etc, etc. Rediculous!
