1 - 3 of 3 Posts
· Registered
I have a 06 coilair and when riding around turns my brake rotor is rubbing bad in the caliper. I have spent lots of time centering the caliper and I think the problem is coming from flex in the swingarm and hub.
I am now thinking of changing to a 12mm axle in the rear. I am planing on buying a Dope 12 kit and a new rear hub
Is there anythin else that I will need to make the conversion ?
Jacob
· Registered
Jacob
The Hayes Mags are a tight fit. You may have some luck removing the pads and using a flat wrench or screwdriver shank to push the caliper pistons back. If the rotor is bent, you can true it with a crescent wrench. Otherwise, Magura, Formula, or Avid brakes will solve the problem. :thumbsup:
1 - 3 of 3 Posts
