I have a few questions about tuning for you other 66 owners out there, and hopefully you can answer some of them.
1) How many clicks of compression should there be?
2) My compression knob gets harder to turn as I add compression dampening, is that norman?
3)The manual states that 15psi is the max preload air pressure, does that mean it is the max for the RC2 leg? or is that considered positive pressure?
4) What is the best way to keep it super plush, and minimize dive? I am still messing with it alot, but I was wondering if anyone had any suggestions.
I am a 185lb freerider/downhiller (for the most part, some all mountain riding from time to time) and its on an enduro 150mm. My current set up is 12psi in the RC2 Leg, 35Psi in the positive, 90 in the negative, 0 in the par, about 4 clicks of compression (from full open), and about mid way on the rebound.
