1 - 9 of 9 Posts
· Displaying UGI Symptoms
What is the difference between these two Rock Shox forks? Are they virtually the same? (travel and etc.)
I have been eyeballing a 454 AIR U-TURN (pricey), however, I can get a new 05 PIKE TEAM AIR for $300.00 at the moment. What should I do?
I ride a Giant VT. I have a Minute 1 on it. The plan would be to put the PIKE on the VT and take off the Minute. Then, next season, ditch the VT in favor of a 5 Spot and put the PIKE on that bike. I have Hope Pro II Hubs that can convert to 20mm thru axle. Any problems with my plan?
THANKS FOR YOUR HELP!
· Registered
I owne the 454 air u-turn, and have spent good time on the pike team air. No performance difference. If there is another new 05 Team Air for $300 I'd buy it.
Discussion Starter · #3 ·
Missed out on the deal - someone else bought it. Thanks anyway Westin!
I'll have to keep my eyes out for another deal like that.
· Registered
Would it be possible to reduce the travel on the non uturn pike air by incresing the neg. air pressure? Would this alter the spring rate in a bad way? I am looking for a sturdy 5 inch fork for my sc blur classic as the warranty forbidding me to do so has expired...
· carpe mañana
The fork comes supplied with a 10mm travel spacer. But yes, you can pump up the negative to drop the travel. I ran my dual air Pike between 130 and 135mm, no problems. DGC reports that if you reduce the travel by a significant amount, like 30mm, then the ride quality suffers.
_MK
1 - 9 of 9 Posts
