So, after a couple of years on an '04 X-5, I'm thinking of moving on to the El Ciclon. What would be the upgrades/benefits of the El Ciclon over the first year X-5 frame? Things I'm looking for would be:
I'd likely go with the quad bearing and RP23 upgrades on the El Ciclon (I have the quad bearings on my X-5, but just the stock Float R shock). I don't mind the taller standover on the El Ciclon - I have pretty long legs and ride with my saddle high.
Any other benefits/differences I'm missing between these two frames? Basically, what I'd hope to achieve would be a slightly lighter bike that would climb and carve downhill turns a little better.
Finally, should I do the owners appreciation trade in program or buy the El Ciclon outright and sell my X-5 frame? I'm thinking the latter would be the better deal. Not sure what I'd get for an older X-5 frame, but I'd have to hope it would be more than $600.
Thanks!!
- lower weight (I think the El Ciclon is a little less girthy than the X-5)
- longer top tube (this one is easy - 24" vs. 23.85")
- lower BB height (the older X-5 with a Pike dialed out to 140mm is a little tall ~ 14" or more at the BB, I think); and
- a slacker head angle (may be about the same, actually, but I've never calculated the head angle of the X-5 with the Pike at 140mm).
Thanks!!
