Mine does the same thing, and I am guessing it's normal. If you adjust the rebound slower/faster the sound will change. Faster rebound and the sound goes by so quick you hardly hear it.KRob said:
I have increased stiction in mine as well, after about 1 month. I decided to open it up and clean it today. I found the left side foam ring totally dry, again. I lifted the seals a few weeks ago and found it dry, so I oiled it up good. Now a few weeks later it's dry again. I also found the left side seals had much more dirt in them than the right. I cleaned them all up and started to put it back together when I came across a major problem... the manual. The manual does not have any info on the internals of the TALAS. So I followed the FLOAT instructions. Well, the internals of the two are so different that I cannot figure out where to put the FLOAT Fluid oil.. top or middle chamber? The Floats only have top and bottom, no middle. So I am totally confused and dissapointed in the FOX manual.
My advice, DON'T take your apart until you see a real manual for the TALAS, AND you have a thin 12mm wrench, and 26mm socket, AND a torque wrench that does inch pounds. It would have cost far less for shipping to have Fox do the work....
