1 - 11 of 11 Posts
MTBR Mafia
i am currently looking at this fork for my heckler with a 5th air on it. will the rake be too much for the good amount of xc i do. and will i have to swap out any spring if i weigh 140 even though it is an air fork? And overall do you guys like the fork?
I ride xc on a z1 sl and the rake is not a problem for me. But of course that may be different for you. You won't need to swap out any springs. You need to adjust the air pressure for your weight and riding preference. I love my fork sucks up all the bumps and handles jumps and drops also.
MTBR Mafia
Discussion Starter · #5 ·
chad1433 said:
Awesome fork for XC. But at 140lbs, maybe too much for your needs? Hard to say. I think it would match well with the Heckler, though.
i said mostly xc with downhills, drops up to 5 or 6 feet, and dj's. so would it still be a lot of fork for me?
thanks
thanks
OK, I do not see where in your first post any mention of "mostly XC" and definately no mention of 5 or 6 foot drops. Definately nothing on DJ. :rolleyes:
Would be a good fork though.
MTBR Mafia
Discussion Starter · #7 ·
ya sorry i was in a hurry. so it would be good know then right?
Time is not a road.
It's basically the same platform as the DJ series, except for the steel steer tube and coil suspension internals. If you're going to be doing more drops and jumps, you might go with the Z1. If you're going to be doing more trail riding, the SL is lighter and more "on the fly" tuneable. The SL is tough enough for freeriding, as it is a FR model, but if you're leaning more towards the freeride aspect of it, I'd go for the Z1 and get the 20mm thru axle.
Just my .02. I loved my Z1 SL but I never jumped or did big drops so I don't really know how much abuse it can take...
C,
I have been using my 03 Z1 SL as my main XC fork for over two years... Once you get it dialed, it rocks. It should be a good match for your Heckler... It should be fine on smaller drops, especially if you are going to tranny.... Being that you are a lighter rider, it should suit you well.
Brian
1 - 11 of 11 Posts
