I have been riding for two years now and have only upgraded the seat and the pedals. Any suggestions for a mainly xc rider? Thanks!
The Hoo Koo has the same frame/tubeset as Fisher's high-end hardtails, so it's not like you'd be putting high-end parts on a low-end frame. The Hoo Koo in stock trim is a nice frame with a budget component spec. Seems like a decent candidate for upgrade to me.Ken in KC said:The amount of money you want to sink in to a Hoo Koo is limited. A fork or wheelset, in my opinion is a poor upgrade choice because you'll spend about as much as what the bike is worth on the upgrade. So at that point, it would make more sense to upgrade the bike.
That makes sense, then. My advice was wrong. I'm not too familiar with the Trek line. My Hoo Koo is steel from the early 90's and worth about $50.Appendage said:The Hoo Koo has the same frame/tubeset as Fisher's high-end hardtails, so it's not like you'd be putting high-end parts on a low-end frame. The Hoo Koo in stock trim is a nice frame with a budget component spec. Seems like a decent candidate for upgrade to me.
I don't know what yours came with, but the stock Bontrager stem and WTB handlebars on my '02 HKEK were incredibly heavy (had no idea until I took 'em off). I've replaced both, pretty cheaply too I might add (I waited for deals) and shaved quite a bit of weight. [Ok, don't ask how much -- I don't actually know. But they stock stuff was heavy enough I could easily feel the difference.]Joe Spicoli said:I have been riding for two years now and have only upgraded the seat and the pedals. Any suggestions for a mainly xc rider? Thanks!
Yep, same as SuperCal, ZR9000 "Platinum" zirconium alloy tubing, whatever the heck that is.Ken in KC said:That makes sense, then. My advice was wrong. I'm not too familiar with the Trek line. My Hoo Koo is steel from the early 90's and worth about $50.
So is the frame on par with a SuperCal or something similar?
Ken
I think that's as good a choice as any for your bike, especially if you can get a good deal on it. I have over 4000 miles on my Marz MXR and it never leaks and there's no slop in the bushings. I also have an old Z2 Bomber on my older bike, high mileage, and similarly bulletproof. Criminy, I've had other forks that needed a rebuild after a ride around the block. Clean the stanchions and spray them with silicon lube after every ride.Joe Spicoli said:thanks for all of the input. any reccomendations on a replacement fork. i was kind of looking at the '05 Marzocchi MX Pro ETA.
The '04 HKEK came with an 80 mm travel fork. 105 mm shouldn't be a huge effect on the geometry, but I would guess that the 120 would.Joe Spicoli said:pricepoint has a 120 mm and a 105 mm. is the 105 betterfor my bike?
Go with the 105. The 120 would be too long. The 105 will be an inch longer than your current fork, theoretically resulting in increased straight-line stability at the expense of manueverability, but as a practical matter, the effect on handling shouldn't be too noticeable.Joe Spicoli said:pricepoint has a 120 mm and a 105 mm. is the 105 betterfor my bike?
