1 - 3 of 3 Posts
When I installed my Hone crankset I could have sworn that the instructions said to use one spacer per side. I've been doing some research and come to find out I should have one on the non drive side and two on the drive side. I've ran it one per side for almost two years with no problems. Which is correct? 68mm shell by the way.
G
I have the same cranks on the same frame. Two spacers on the drive side and one on the nondirve side. All three spacers are required on a 68 mm shell with a non-E-type front der.
1 - 3 of 3 Posts
