03 Marin Wolf Ridge
1940 Views 11 Replies 5 Participants Last post by  Reek
I was wondering if any of you guys knew it it was possible to put a 6" travel fork on an 03 Marin Wolf Ridge? How would it change the geometry and what new stresses would be put on the frame?
thor
1 - 12 of 12 Posts
I'm running a 5" Fox Vanilla on Marin Trail pro which is similar. Yes it slackens the head tube into a more downhill like stance so it works much better going down than up.Climbing is harder but I compensated with a longer stem and moving my seat up on the seatpost so its working out fine. Going another inch I would not do. Also if you are planning to put on a double crown fork you better check with Marin, I'm not sure if the headtube is burly enough to handle the stresses of a double crown fork.
some good points, but why can I get 6"inches of travel in the back if I can't upgrade the fork to match?
I swapped rear shocks from a 1.8 inch throw to a 2.2 inch throw, bearly fit but its pushing about 7" of rear suspension now, I'm not sure if your bike allows you to put in a longer throw rear shock but if it does and you are on the large/heavier side of life its a viable option. But don't look for it to balance out your long throw front fork much.
I have an 01 wolf ridge with 150 mm on the front...
and it works great. I put the steerer angle setting at its slackest (69 deg) and put the rear travel to 6 inches.
no problems. Obviously doesn't climb like my NRS or even my Dakar XLT but it works great especially at Plattekill.
REEK
Gotta luv that Fugly mud guard.
What's up with the chalk outline in front of the bike in the photo? Did someone die there? :D
REEK
Is it manageable on the climbs. This is going to be my only bike?
Yes it is manageable but....
It is manageable on my 01. I have a fox float RL. Don't use the lock out much. The bob seems worse with the head angle in the 70 or 70.5 setting but in the 69 setting with 6 inch rear, the rear end actually stiffens up on climbs as you might expect with a high single pivot bike.
As long as you 're not obsessed with overall pedalling efficiency, I say go for it. I use my bike as my main ride.
REEK
I will post some soon!
I'll get some pics of my Wolf Ridge up in a bit. It's in the middle of a mid summer tear down that all started when I went to replace the bottom bracket. One thing lead to another and now it's getting the 'works'. Brakes "NEED" bleeding, hubs "NEED" packing, fork "NEEDS" a tear down...
You get the idea.
Anyway, keep an on out for the pics.
REEK
1 - 12 of 12 Posts
