1 - 2 of 2 Posts
Hey
I'm getting my fork serviced to let a friend borrow it. It was originally on a heckler. But now having the fork set at 100mm to fit a classic blur. My friend is about 130 lbs, rides xc, and very slow over technical stuff; how should the fork be setup, spring weight, oil weight?
thanks
carpe mañana
jr711 said:
Hey
thanks
You may want to use a lighter oil than stock. Use Fox recommended spring. If it is too much, you can remove the assist coil off the damper.
_MK
1 - 2 of 2 Posts
