I would not put fluid into the fork if it was not designed for it. You will get hydraulic lock-out and you won't get full compression. Just keep the fork clean and check to make sure you have the rebound knob attached correctly.DH_WP said:
I would not put fluid into the fork if it was not designed for it. You will get hydraulic lock-out and you won't get full compression. Just keep the fork clean and check to make sure you have the rebound knob attached correctly.DH_WP said:Hi
I have a old black super air 100/120mm , and ride it in the 100 setting.
The problem is with my new bike "Titus Switchblade" with a 4.5" rear travel the back of the bike is outperforming the front.
I can either upgrade to a Talas RCL . or a minute 3 .. (cant decide) or I can try and tweak my black.
I first noticed my black was "off" when I took my bike to the LBS and they guy there was playing on my bike , he asked if I like my rebound so slow .. I was like .."but that is the fastest it can go"..
Since then I have replaced the 5wt oil with 3wt and installed Evil-G seals.
I took the fork apart and re-lubed it , then i created my own sort of semi-bath system by pouring about 10cc or 3wt fork oils in the lowers. "Not sure if this was the right thing to do or not ?" could somone please assist ?
I am also wondering if it will be possible to pump oil into the fork via the micro-port lubes ? to keep the fork running smoothly with the standard manitou clear type grease.
any help would be great thanks![]()
I don't think so. Without the bushings being modified to allow for the oil to move around, you will get lock out.Hecubus said:There must be something wrong with your fork. Substituting the oil with 3w is not the solution. At the fastest rebound with 5w oil the fork should be almost like a pogo stick with no damping at all. The Black rebound adjuster typically has a very wide and very noticeably effective range of rebound damping. It should be ok to convert it to a semi bath system using the new seals but 10cc of 3w oil is too little and too light. The 5-40W synthetic they recommend is notably more viscous and you should use 16cc per leg as per Manitou's recommendation.
