xbrinelax2011 said:
that's pretty much what I was thinking of. Would it be possible to do that with my sherman?
No.
Perhaps you should re-read his post and mine.
The USB Molly is designed around 24 inch wheels and a suspension fork.
The Sherman is a 20 inch BMX bike. It is designed around a rigid BMX fork. Adding a suspension fork for 26" wheels will make the front end much taller, much slacker, slack out the seat tube angle, as well as raise the BB height. Obviously a 26" wheel is not going to fit in the rear end. Let's apply a little common sense. And of course there is the issue that the rear end on each frame is a different width... something that you should have been able to realize for yourself.
The bottom bracket on the Sherman is not a euro threaded like it is on the HR... will not work. The bottom bracket SHELL on the BMX frame is much larger than that of the HR. You should have been able to tell this as well.
In fact, from a visual inspection, you should have been able to deduce (on your own) that the majority of parts would not transfer over.
Specialized uses something like a 30.9 seatpost... I can guarantee the BMX frame will be smaller.
Also, I don't appreciate the PMs you sent me:
dude wtf you don't have to be a dousche I'm not making you answer my threads.
Perhaps you should think things through on your own. Perhaps you should not lie about bikes that you do not own. Perhaps you should work on your spelling, capitalization, and punctuation.
You asked for help, I offered it. When I corrected you in your other thread, you got all offended and tried to say that's what you meant. Sorry, 1 3/8 IS another headset size... and it is NOT the same as 1 1/8... and there is a whole key between 1 and 3 on the keyboard. On top of that, that is information that could have been easily found had you searched. This thread could have been avoided entirely if you had thought about it a little bit.
And the spam about selling your frame in both your other threads is against posting guidelines. It went something like: "I might sell you my Hardrock and some random stuff, but I might want to keep it."
Grow up. Grow some thicker skin. Use your head.
