Interbike 2004
Reba Race 29er
RockShox Reba 29er Fork
The RockShox 29-inch Reba fork will offer a true suspension choice for the expanding 29-inch segment and will be exclusive to Gary Fisher® bikes in ‘05. With a maximum travel of 100mm and weighing in at sub-four pounds, the 29-inch fork has been engineered to take advantage of the mechanical benefits of the larger diameter wheelset. The RockShox Reba delivers unparalleled performance with RockShox’s completely innovative Motion Control Damping as well as the Dual Air spring system.
Motion Control is a revolutionary new damping system, designed from the ground up, with the requirements of today’s mountain bikes in mind.
System benefits include:
- Wide range of usable set up choices
- Functional adjustments that can be felt by the user
- Easy “On-the-Fly” adjustability
- Light Weight
- Easy to Service
The Reba 29 also utilizes RockShox’s Dual Air spring technology, which is the lightest and most adjustable air spring available. This exclusive system features a combination of adjustable positive and negative air chambers for the ultimate in a custom fork feel, allowing for infinite adjustability of the spring rate and spring curve. Dual Air also allows the rider to control the initial plushness of the fork without affecting the spring rate or bottoming resistance.
Throw into the mix new PopLoc remote adjuster, stiff yet light 32mm upper tubes, and new integrated cable routing for remotes and disc brakes, and you’ll see, a new day is dawning.
Reba 29 inch fork:
Spring: Dual Air
Travel: 80mm
Adjust: Positive and Negative Schrader Valves, External Rebound, Floodgate, Compression Adjust and Lock PopLoc Remote Option
Damping: Motion Control
Lowers: One piece magnesium, Disc Only
Crown: Light Weight Forged 6061 Aluminum
Steerer Tube: Butted Aluminum
Upper Tubes: 32mm EA70 Straight Wall Aluminum, Low Friction Anodized
Colors: Silver, Black
<< Previous
Back to the Rock Shox booth
Interbike - Trade Show Booths
