Interbike 2008 - MTBR
Gravity Dropper in the Alps
-Made in the USA from CNC'd 7075 T-6 aircraft aluminum.  This high grade aluminum allows for strong lightweight units.
-Weight.  The whole seatpost, including all hardware, switch and cables is 450 grams.  The benefits gained from the GravityDropper far surpass the tiny amount of non-rolling weight you might add..
-Sizes available- 26.8, 27.0 and 27.2 Shims available for larger Posts including 28.6 , 29.2, 29.8, 30.0, 30.2, 30.4, 30.8, 30.9, 31.6, 31.8 and 34.9
-Standard Length is 350 mm.  Shorter lengths of 275,300,325,mm and longer lengths of 375,400 are available.
-Available in 2inch, 3inch standard and 4inch drop.   Also available in a multiposition. (UP, Down 1 inch, Fully down)
(Gravitydropper in foreground, Alsp in background)
Next >>
Back to the Gravity Dropper booth
BMC:
Aero Tech Designs:
