Interbike 2008 - MTBR
Mission 1
Mission 1 ‘09
Built up using the same revolutionary 6? all-mountain frame found on its two brothers, the Mission 1 is also an amazing bike. Sure, there was more of an emphasis put on making the Mission 1 available at a more affordable price, but don’t let that concern you. With components from Fox, Truvativ, SRAM, Sun, Hayes, Easton, and WTB; the Mission 1 is also a great time waiting to happen.
  • Mission 6" All-Mountain Frame w/ Knuckle Box Rear Suspension , Hooded Hydroformed Top Tube & Sealed Cartridge Bearing Pivots
  • Fox Vanilla R 140mm Coil Fork w/ Tunable Pre-Load / Rebound, Hollow Forged Crown
  • Fox Float RP2 Rear Shock w/ Tunable Rebound, 2 Position ProPedal w/ Quick Flip On/Off Lever
  • Hayes Stroker Ryde Hydraulic Disc Brakes w/ V7" / V6" rotors
  • Truvativ Blaze Crankset w/ 44/32/22t Rings & Powerspline Sealed Bearing Bottom Bracket
  • SRAM X.5 9-spd Trigger Shifters / X.7 Rear Derailleur
  • Easton EA30 Stem / Bar
  • Sun Ditch Witch Double Wall Rims
  • WTB Prowler MX / Stout 2.3 Folding Tires
  • WTB Pure V Sport Saddle
    Specs:
  • Sizes: SM (15.5"), MD (17"), LG (19"), XL (21")
  • Frame: Mission All Mountain 6" Aluminum w/ Hooded Hydroformed Top Tube, Butted / Formed Down Tube / Seatstays, Under Arch Seatstay bridge, Knuckle Box Technology, ISCG, Hammerschmidt Ready
  • Fork: Fox Vanilla R 140mm travel, coil spring w/ext. pre-load / rebound adj., hollow forged crown
  • Rear Shock: Fox Float RP2 200x51mm Air w/ rebound adj, 2
  • Cranks: Truvativ Blaze PowerSpline 3.1 AL-66 arms, AL-7075 aluminum outer ring, 22/32/44t
  • Bottom Bracket: Truvativ Power Spline Sealed Cartridge
  • F. Derailleur: Shimano Deore dual pull, top swing
  • R. Derailleur: SRAM X-7
  • Shifter: SRAM X-5 9spd trigger
  • Brake Levers: Hayes Stroker - Ryde
  • Brakes: Hayes Stroker Ryde Hydraulic V7" frt / V6" rear Rotors
  • Gear: SRAM PG-950 9spd Cassette (11-34t)
  • Rims: 32h Sun Ditch Witch w/ Eyelets
  • Tires: WTB Prowler MX 2.3 frt, Stout 2.3 rear, Folding
  • Pedals: DB Sound Alloy w/ molded traction pins
  • Handlebar: Easton EA30 MidRise 31.8mm
  • Stem: Easton EA30 31.8mm
  • Seatpost: DB SL309p Alloy Micro Adjust 30.9mm
  • Seat: WTB Pure V Sport
  • Headset: Zero Stack 1 1/8"
  • Colors: Gloss RED
  • Chain: Zero Stack 1 1/8"
  • Hubset: (F) 32h Alloy w/ CNC Disc Mount (R) 32h Alloy Cassette w/ CNC Disc mount
  • Spokes: Black 14g Stainless Steel
  • Grips: DB Brics 130mm D2 Kraton
  • Extras: DB Key Chain, Owner’s manual / Mission owner's manual cover, Chainstay Protector, Clear Coat, H20 bottle mounts
  • << Previous Next >>
    Back to the Diamondback booth
    Niner:
    pHastLegs NEW:
