Interbike 2008 - MTBR
Mission 2
Mission 2 ‘09
The Mission 2 is built up using the same revolutionary 6? all-mountain frame and many of the parts found on the top of the line Mission 3. No single ring / two speed transmission, but the Mission 2 is a very nice bike. Upgrades from the Mission 1 include a Fox Float R Air fork with a 15mm thru axle, SRAM X.7 Trigger shifters, and Hayes Stroker Trail hydraulic disc brakes.
  • Mission 6" All-Mountain Frame w/ Knuckle Box Rear Suspension , Hooded Hydroformed Top Tube & Sealed Cartridge Bearing Pivots
  • Fox Float R 150mm Air Fork w/ Lockout & Tunable Rebound / Compression, Magnesium Lowers, 32mm Easton Aluminum Stanchions & 15QR Thru Axle
  • Fox Float RP2 Rear Shock w/ Tunable Rebound, 2 Position ProPedal w/ Quick Flip On/Off Lever
  • Hayes Stroker Trail Hydraulic Disc Brakes w/ V7" / V6" rotors
  • Truvativ Fire-X Crankset w/ 44/32/22t Rings & External Giga X Pipe Sealed Bearing Bottom Bracket
  • SRAM X.7 9-spd Trigger Shifters / X.9 Rear Derailleur
  • Easton EA50 Stem / Bar / Seat Post
  • Sun Equalizer Double Wall Disc Rims
  • WTB Prowler MX / Stout 2.3 Folding Tires
  • WTB Pure V Sport Saddle
    Specs:
  • Sizes: SM (15.5"), MD (17"), LG (19"), XL (21")
  • Frame: Mission All Mountain 6" Aluminum w/ Hooded Hydroformed Top Tube, Butted / Formed Down Tube / Seatstays, Under Arch Seatstay bridge, Knuckle Box Technology, ISCG, Hammerschmidt Ready
  • Fork: Fox Float R air, 150mm travel, open bath, w/ ext. rebound adj. , butted Alloy steerer, 32mm Easton aluminum stanchions, magnesium lowers, w/15mm thru axle
  • Rear Shock: Fox Float RP2 200x51mm Air w/ rebound adj, 2
  • Cranks: Truvativ Fire X Giga X Pipe w/ AL-7075 aluminum outer ring, 22/32/44t
  • Bottom Bracket: Truvativ Giga X Pipe Outboard Sealed Cartridge
  • F. Derailleur: Shimano Deore dual pull, top swing
  • R. Derailleur: SRAM X-9
  • Shifter: SRAM X-7 9spd trigger
  • Brake Levers: Hayes Stroker - Trail w/ Reach adj.
  • Brakes: Hayes Stroker Trail Hydraulic V7" frt / V6" rear Rotors
  • Gear: SRAM PG-950 9spd Cassette (11-34t)
  • Rims: 32h Sun Equalizer w/ Eyelets
  • Tires: WTB Prowler MX 2.3 frt, Stout 2.3 rear, Folding
  • Pedals: DB Sound Alloy w/ molded traction pins
  • Handlebar: Easton EA50 MidRise 31.8mm
  • Stem: Easton EA50 31.8mm
  • Seatpost: Easton EA50 Double bolt clamp 30.9mm
  • Seat: WTB Pure V Sport
  • Headset: Zero Stack 1 1/8" ACB w/ deep Alloy cups
  • Colors: Goat White
  • Chain: Zero Stack 1 1/8" ACB w/ deep Alloy cups
  • Hubset: (F) 32h Neau Naim Alloy Sealed Bearing Disc w/ 15mm Thru Axle (R) 32h Alloy Disc Cassette w/ CNC Disc mount
  • Spokes: Black 14g Stainless Steel
  • Grips: DB Brics 130mm D2 Kraton
  • Extras: DB Key Chain, Owner’s manual / Mission owner's manual cover, Chainstay Protector, Clear Coat, H20 bottle mounts
  • << Previous Next >>
    Back to the Diamondback booth
    Avid:
    Hutchinson:
