Interbike 2008 - MTBR
Sortie 1
Sortie 1 ‘09
If you’re looking to push your limits on an amazing trail bike, but without finding the limit of your credit, look no further than the new Sortie 1. Built up with the same frame found on every other Sortie trail bike, and with components from Rock Shox, Hayes, Shimano, Avenir, and WTB; the Sortie 1 is one solid trail bike.
  • Sortie 5" Trail Frame w/ Knuckle Box Rear Suspension, Hooded Hydroformed Top Tube & Sealed Cartridge Bearing Pivots
  • Rock Shox Tora 289 120mm Fork w/ Rebound Adjust
  • Rock Shox BAR Air Rear Shock w/ Rebound Adjust
  • Hayes HMX-4 Disc Brakes w/ 6? Rotors
  • Truvativ ISO-Flow Crankset w/ 44/32/22t Rings & Sealed Bearing Bottom Bracket
  • SRAM X.5 9-spd Trigger Shifters / X.7 Rear Derailleur
  • Avenir 100 Series Stem / Bar / Seat Post
  • Weinmann Double Wall Disc Rims
  • WTB Prowler MX 2.1 Tires
  • WTB Rocket V Saddle
    Specs:
  • Sizes: SM (15.5"), MD (17"), LG (19"), XL (21")
  • Frame: Sortie Trail 5" Aluminum w/ Hydroformed Top Tube, Butted / Formed Down Tube / Seatstays, Under
  • Arch Seatstay bridge, Knuckle Box Technology
  • Fork: Rock Shox Tora 289 120mm travel coil spring, w/ rebound damping adj.
  • Rear Shock: Rock Shox BAR 2.1 190x50mm Air w/ rebound adj
  • Cranks: Truvativ Iso-Flow 3.0 w/ replaceable rings, 22/32/44t
  • Bottom Bracket: Sealed Cartridge
  • F. Derailleur: Shimano Deore dual pull, top swing
  • R. Derailleur: SRAM X-7
  • Shifter: SRAM X-5 9spd trigger
  • Brake Levers: Hayes HML
  • Brakes: Hayes HMX-4 Disc w/ 6" Rotors
  • Gear: SRAM PG-950 9spd Cassette (11-34t)
  • Rims: 32h Weinmann XM260 Doublewall Disc
  • Tires: WTB Prowler MX 26x2.1
  • Pedals: DB Toe Clip Compatible Platform
  • Handlebar: Avenir 100 Series 31.8mm low rise
  • Stem: Avenir 100 Series 10° 31.8mm
  • Seatpost: Avenir 100 Series Micro Adjust 30.9mm
  • Seat: WTB Rocket V
  • Headset: Integrated "Cane Creek" Size Drop-in ACB 1 1/8"
  • Colors: Satin Silver
  • Chain: Integrated "Cane Creek" Size Drop-in ACB 1 1/8"
  • Hubset: (F) 32h Alloy w/ CNC Disc Mount (R) 32h Alloy Disc Cassette w/ CNC Disc mount
  • Spokes: Black 14g Stainless Steel
  • Grips: DB 130mm D2 Kraton
  • Extras: DB Key Chain, Ownerâ??s manual / Sortie owner's manual cover, Chainstay Protector, Clear Coat, H20 bottle mounts
  • << Previous Next >>
    Back to the Diamondback booth
    Intense 2011:
    Scott:
