Interbike 2008 - MTBR
Sortie 2
Sortie 2 ‘09
No one likes to be stuck in the middle, but the Sortie 2 is completely alright being compared to the Sortie 3 and watching over the Sortie 1. The Sortie 2 is built up with the same top-notch trail frame featured on the rest of the series and is well-equipped with too much good stuff. Upgrades from the Sortie 1 include a Fox 32 Float R air fork and Float RP2 rear shock, Truvativ 5D 3.1 crank set, and Avid Juicy 3 hydraulic disc brakes.
  • Sortie 5" Trail Frame w/ Knuckle Box Rear Suspension, Hooded Hydroformed Top Tube & Sealed Cartridge Bearing Pivots
  • Fox 32 Float R 130mm Air Fork w/ External Rebound Control, Butted Aluminum Steerer, Magnesium Lowers, 32mm Easton Aluminum Stanchions
  • Fox Float RP2 Rear Shock w/ Tunable Rebound, 2 Position ProPedal w/ Quick Flip On/Off Lever
  • Avid Juicy 3 Hydraulic Disc Brakes w/ 185mm frt / 160mm rear rotors
  • Truvativ 5D 3.1 Crankset w/ 44/32/22t Rings & Power Spline Sealed Bearing Bottom Bracket
  • SRAM X.5 9-spd Trigger Shifters / X.7 Rear Derailleur
  • Easton EA30 Stem / Double Bolt Seat Post
  • WTB Speed Disc Double Wall Rims
  • WTB Prowler MX 2.1 Tires
  • WTB Rocket V Saddle
    Specs:
  • Sizes: SM (15.5"), MD (17"), LG (19"), XL (21")
  • Frame: Sortie Trail 5" Aluminum w/ Hydroformed Top Tube, Butted / Formed Down Tube / Seatstays, Under Arch Seatstay bridge, Knuckle Box Technology
  • Fork: Fox 32 Float R Air, 130mm travel, open bath, with ext. rebound knob, butted Alloy steerer, 32mm Easton aluminum stanchions, magnesium lowers
  • Rear Shock: Fox Float RP2 190x51mm Air w/ rebound adj, 2
  • Cranks: Truvativ 5D 3.1 power spline w/ 7075 aluminum outer ring, 22/32/44t
  • Bottom Bracket: Truvativ Power Spline Sealed Cartridge
  • F. Derailleur: Shimano Deore dual pull, top swing
  • R. Derailleur: SRAM X-7
  • Shifter: SRAM X-5 9spd trigger
  • Brake Levers: Avid Juicy 3
  • Brakes: Avid Juicy 3 Hydraulic Disc w/ 185mm frt / 160mm rear Rotors
  • Gear: SRAM PG-950 9spd Cassette (11-34t)
  • Rims: 32h WTB Speed Disc w/ Eyelets
  • Tires: WTB Prowler MX 26x2.1
  • Pedals: DB Toe Clip Compatible Platform
  • Handlebar: Avenir 100 Series 31.8mm low rise
  • Stem: Easton EA30 31.8mm
  • Seatpost Easton EA30 Double bolt clamp 30.9mm
  • Seat: WTB Rocket V
  • Headset: Integrated "Cane Creek" Size Drop-in ACB 1 1/8"
  • Colors: Orange Peeler Metallic
  • Chain: Integrated "Cane Creek" Size Drop-in ACB 1 1/8"
  • Hubset: (F) 32h Alloy w/ CNC Disc Mount (R) 32h Alloy Cassette w/ CNC Disc mount
  • Spokes: Black 14g Stainless Steel
  • Grips: DB 130mm D2 Kraton
  • Extras: DB Key Chain, Owner’s manual / Sortie owner's manual cover, Chainstay Protector, Clear Coat, H20 bottle mounts
  • << Previous Next >>
    Back to the Diamondback booth
    Rock Shox:
    Salsa:
