Interbike 2008 - MTBR
Sortie Limited Edition
Sortie Black ‘09
Introducing the 5" travel, sub 26.5 lb. Sortie Black. We were having so much fun redesigning the Sortie platform to bump up the travel to 5" for all of the Sortie bikes, and making all of them lighter, that we decided to take things a step further. The result is an extremely lightweight limited edition trail terror we call the Sortie Black. More travel than before and less weight than any other Sortie in the line.Upgrades from the Sortie 3 include a Fox 32 Float RLC Air fork, 15mm thru axle, Truvativ NOIR Giga X Pipe crank set, SRAM XO shifters and rear derailleur, Mavic Crossmax SLR wheel set, and a set of Hayes Stroker Gram hydraulic disc brakes.
  • Sortie 5” Trail Frame w/ Knuckle Box Rear Suspension, Hooded Hydroformed Top Tube & Sealed Cartridge Bearing Pivots
  • Fox 32 Float RLC 130mm Air Fork w/ External Rebound / Compression / Lockout Controls, Butted Aluminum Steerer, Magnesium Lowers, 32mm Easton Aluminum Stanchions & 15QR Thru Axle
  • Fox Float RP23 Rear Shock w/ Tunable Rebound, 3 Position ProPedal w/ Quick Flip On/Off Lever
  • Hayes Stroker Gram Hydraulic Disc Brakes w/ V7” / V6” rotors / Adjustable Reach Levers
  • Truvativ Noir Crankset w/ 44/32/22t Rings & External Giga X Pipe Sealed Bearing Bottom Bracket
  • SRAM XO 9-spd Trigger Shifters / Rear Derailleur
  • Easton Monkey Lite XC CNT Carbon Bar, EA90 Stem / Seat Post
  • 24h Mavic Crossmax SLR Double Wall Disc Wheels w/ QRM+ Bearings, Straight Pull Zircal Aluminum Spokes, 15QR Thru Axle
  • WTB Wolverine UST 2.2 Folding Tires
  • WTB Devo Carbon Saddle
    Specs:
  • Sizes: SM (15.5"), MD (17"), LG (19"), XL (21")
  • Frame: Sortie Trail 5" Aluminum w/ Hydroformed Top Tube, Butted / Formed Down Tube / Seatstays, Under Arch Seatstay bridge, Knuckle Box Technology
  • Fork: Fox 32 Float RLC Air, 130mm travel, open bath, with ext. compression / rebound / lock out knobs butted Alloy steerer, 32mm Easton aluminum stanchions, magnesium lowers, w/15mm thru axle
  • Rear Shock: Fox Float RP23 190x51mm Air w/ rebound adj, 3
  • Cranks: Truvativ NOIR Giga X Pipe 3.3 AL-66 arms, 7075 aluminum outer/middle/inner rings, 22/32/44t
  • Bottom Bracket: Truvativ Giga X Pipe Outboard Sealed Cartridge
  • F. Derailleur: Shimano 770 XT dual pull, top swing
  • R. Derailleur: SRAM XO Medium Cage
  • Shifter: SRAM XO 9spd trigger
  • Brake Levers: Hayes Stroker - Gram w/Reach adj.
  • Brakes: Hayes Stroker Gram Hydraulic Disc w/ V7" frt / V6" rear Rotors
  • Gear: SRAM PG-990 9spd Cassette (11-34t)
  • Rims: 24h Mavic Crossmax SLR
  • Tires: WTB Wolverine 2.2 UST, Folding
  • Pedals: DB Sound Alloy w/ molded traction pins
  • Handlebar: Easton Monkey lite XC CNT LoRise Carbon 31.8mm
  • Stem: Easton EA90 31.8mm
  • Seatpost: Easton EC90 CARBON Double bolt clamp 30.9mm
  • Seat: WTB DEVO Carbon
  • Headset: Integrated "Cane Creek" Size Drop-in ACB 1 1/8"
  • Colors: Black n' Blue
  • Chain: Integrated "Cane Creek" Size Drop-in ACB 1 1/8"
  • Hubset: (F) 24h Mavic Crossmax SLR Disc 15mm Thru Axle (R) 24h Mavic Crossmax SLR Disc Cassette
  • Spokes: Mavic Crossmax SLR, Zircal Double Butted Bladed
  • Grips: DB 130mm D2 Kraton
  • Extras: DB Key Chain, Owner’s manual / Sortie owner's manual cover, Chainstay Protector, Clear Coat, H20 bottle mounts
  • Next >>
    Back to the Diamondback booth
    WTB:
    pHastLegs NEW:
