Interbike 2008 - MTBR
ScapeGoat
Scapegoat ‘09
When we brought the original ScapeGOAT to the 2007 Interbike tradeshow, we brought it only to be ogled over and to show the world another one of the many ways the revolutionary Knuckle Box suspension platform could be put to good use to create great times. We knew the bike would be a show-stopper, but we honestly didn’t expect the herds of onlookers who quickly gathered around it to take a look. The bike that was developed originally to be a prototype used to test the limits of the Mission frame quickly went from serving that purpose to becoming a concept bike, to becoming a limited edition. For 2009, we decided that everyone ought to have a chance to not only look at the ScapeGOAT, but get in line for one. Like the original, the 2009 model will be made available, but only in very limited quantities.
The ScapeGOAT is an aggressive all-mountain / park bike that uses the Mission-proven frame design with 6 inches of travel in the rear and 160mm in the front compliments of the Fox 36 Float RC2 fork. The ScapeGOAT’s frame is essentially a Mission frame, but with a more robust straight gauge down tube for added strength, a 1.5" head tube, and an ISCG chain guide mount. The list of parts that make up the ScapeGOAT looks like something you’d jot down soon after you found out you’d just won the lottery, but fortunately for you, your friends at Diamondback put them into a package and made it surprisingly affordable.
  • ScapeGOAT 6" Aggressive All-Mountain Frame w/ Knuckle Box Rear Suspension, 1.5" Head Tube, Hooded Hydroformed Top Tube, Butted / Formed Down Tube / Seatstays, UnderArch Seatstay bridge, Sealed Cartridge Bearing Pivots
  • Fox 36 Float RC2 OnePointFive 160mm Fork w/ External High/Low Speed Compression Adj, Air Spring & Rebound Adj, Internal Bottom-Out Resistance, 36mm Aluminum Stanchions, 20mm QR Thru Axle
  • Fox DHX Air 5.0 Rear Shock w/ Rebound, Bottom Out Pressure, Air Spring Pressure, 2 Position Propedal
  • Truvativ Hammerschmidt FR 2-Spd Cranks w/ Aluminum All-Mountain Chainring guard, 22/36t, Hammerschmidt Sealed Bearing Bottom Bracket
  • SRAM XO 9-spd Trigger Shifters / Short Cage Rear Derailleur
  • 24h Mavic Crossmax SX Wheels w/ QRM+ Bearings, Straight Pull Zircal Aluminum Spokes, 20mm Thru Axle
  • Avid CODE 4 Piston Hydraulic Disc Brakes w/ 203mm frt / 185mm rear rotors, Avid CODE levers w/ Center Mount Speed Dial Contact Point Adj, 3 cartridge bearing lever pivot
  • Answer Pro Taper Oversize 31.8mm 2? Rise Handlebar, Truvativ Holtzfeller Stem
  • WTB Prowler MX 2.5 / Stout 2.3 Folding Tires
  • WTB Laser V Race - DB Edition Saddle / Truvativ Team Post w/Double Bolt Clamp
    Specs:
  • Sizes: SM (15.5"), MD (17"), LG (19")
  • Frame: Scapegoat Aggressive All Mountain 6" Aluminum w/ Hooded Hydroformed Top Tube, Butted / Formed Down Tube / Seatstays, Under Arch Seatstay bridge, Knuckle Box Technology, OnePointFive Head Tube, Break Therapy Mount, ISCG, Hammerschmidt Ready
  • Fork: Fox 36 Float RC2, OnePointFive, 160mm travel, ext. high/low speed compression adj, air spring and rebound adj. Internal bottom-out resistance damper, 36mm aluminum stanchions, 20mm QR thru axle
  • Rear Shock: Fox DHX Air 5.0 200x51mm w/ rebound, bottom o
  • Cranks: Truvativ Hammerschmidt FR 2 speed w/ aluminum all mountain chainring guard, 22/36t
  • Bottom Bracket: Truvativ Hammerschmidt Sealed Cartridge
  • F. Derailleur: Not Needed
  • R. Derailleur: SRAM XO Short Cage
  • Shifter: SRAM XO 9spd trigger
  • Brake Levers: Avid CODE, center mount Speed Dial contact point adj, 3 cartridge bearing lever pivot
  • Brakes: Avid CODE, 4 piston Hydraulic Disc w/ 203mm frt / 185mm rear Rotors
  • Gear: SRAM PG-990 9spd Cassette (11-34t)
  • Rims: 24h Mavic Crossmax SX, Maxtal Aluminum, SUP, Disc
  • Tires: WTB Prowler MX 2.5 frt, Stout 2.3 rear, Folding
  • Pedals: DB Sound Alloy w/ replaceable traction pins
  • Handlebar: Answer Products Pro Taper OS 2" Riser 31.8mm
  • Stem: Truvativ Holtzfeller 31.8mm
  • Seatpost: Truvativ Team Double bolt clamp 30.9mm
  • Seat: WTB Laser V Race
  • Headset: Zero Stack 1.5" FSA Orbit E 1.5 ACB w/ deep Alloy cups
  • Colors: Black Sheep
  • Chain: Zero Stack 1.5" FSA Orbit E 1.5 ACB w/ deep Alloy cups
  • Hubset: (F) 24h Mavic Crossmax SX, QRM+ Bearings, Full CNC Shell for Straight Pull Zircal Spokes, 20mm Thru Axle (R) 24h Mavic Crossmax SX, QRM+ bearings, full CNC shell for straight pull Zircal spokes, FXT-L Cassette body
  • Spokes: Mavic Crossmax SX, Zircal Round
  • Grips: DB Brics 130mm D2 Kraton
  • Extras: DB Key Chain, Owner’s manual / Mission owner's manual cover, Chainstay Protector, H20 bottle mounts
  • << Previous
    Back to the Diamondback booth
    Interbike - Trade Show Booths
